Brand New Rack & Pinions.
Old Dec 31, 2007 | 06:27 PM
bluegrass_boy62's Avatar
Does anyone know where to buy brand new rack and pinion setups for our cars? Ive looked at Summit and Jegs and couldnt find anything.
Old Jan 1, 2008 | 03:39 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: Brand New Rack & Pinions.
You may need to put a k member in for ease of installing a rack, heres a few I know of..
http://www.jegs.com/webapp/wcs/store...52071_-1_11177
http://www.americanracecomponents.com/camaro.html
http://www.bmrfabrication.com/F3-chassis.htm
http://paracing.com/product_info.php...eb927a04a87078
http://www.racecraft.com/products.php?cat=42
http://www.racecraft.com/proddetail....d=4282xxxxxxxx
http://www.yellowbullet.com/forum/sh...ad.php?t=10267
Old Jan 1, 2008 | 11:38 AM
So having a k-member makes the insertion of a rack and pinion easier? Is the steering feel alot better with a rack and pinion? Nice ride by the way!
Old Jan 1, 2008 | 02:01 PM
malkavian's Avatar
ok so are these tubular k-members just for drag cars or will they help with cornering? Straight line racing or something more like auto x .. I just noticed some were listed for drag cars.
Old Jan 1, 2008 | 02:10 PM
Well, I would think most are geared toward drag racing....the pinto rack is a manual, no power assist. I cannot think of a power rack kit but I`m sure it is out there. I would think it would work for auto X if you had a good steer ratio. I have 2 guys with racks in there cars that live near me and 1 is a dedicated race car the other is a "pro street" cruises and shows and some racing. I want to install one, I have a manual gear box as of now.
Old Jan 1, 2008 | 02:52 PM
Im not really looking to build a drag car, just a really nice street bruiser. Plan on doing the LS1/T56 swap. Any suggestions?
Old Jan 1, 2008 | 03:15 PM
Well since these cars don't come with a rack & pinion setup in the first place, there's not going to be "new" ones floating around someplace, like you could go to VatoZone and buy it like a water pump or something.
Next, since the cars didn't come with them, there's nowhere to mount one to.
Third, since the cars didn't come with them, the whole steering system is set up differently; according to the design that they DID come with. Out of which, the single biggest difference is, a rack & pinion only moves from side to side by a relatively short distance; so even if you were to fab one up onto the "frame" somehow, you'd discover that the car has a turning radius of about a mile, because the R&P moves the spindles so little.
Fourth, there are no spindles that fix issue #3, that come in any kind of car. What you'd need is ones with the steering "arm" made MUCH shorter: i.e., purpose built for that one setup. Modifying stock ones is not for the average amateur, let alone for some hack like me; since if it fails, you have no control whatsoever over the direction that the wheel points. I can envision situations where that would not be a good thing.
So: you need a different K-member (or some SERIOUS modifications to the one that's there); and well-engineered modified spindles.
For most of us, it would be pretty pointless to go through all that, for what little benefits it would provide. A whole lotta maze to get to very little cheese.
Old Jan 2, 2008 | 12:42 PM
Shagwell's Avatar
Car: projects.......
- do a search. The topic has been covered many times.
Basically, the effort involved to properly set-up a rack in our cars for anything other than strip racing is not worth the minimal "gains" of a rack, especially with the "on-center" wear comon to rack units.
Ed1LE
Sep 30, 2018 09:14 AM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
loud91rs
Oct 5, 2015 10:05 PM
