killing rear shocks to fast??
Old Jan 9, 2008 | 02:28 AM
chevy boi's Avatar
Car: 1989 i roc-z28
Engine: 350 tpi l98
ok for some reason my car is killing every set of freaking shocks i put on it in about 3 months. the first set was a was some kyb's and i from what i read on here they are knowned to go out quickly so i ignored it. then i got some Monroe road warriors and those lasted a whopping 2 months. and my lastest set of gaberials deside to die in about 3 months. what is causing this?
the car is a 89 IROC and it was raced on occasion, but is that enough to kill the shocks that quickly. could it be saggy springs? it getting real bad now cuz i can clearly see where my bump stops are hitting my axle housing
Old Jan 9, 2008 | 08:08 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Re: killing rear shocks to fast??
Simple, stop buying cheap shocks and spend the money on a decent set. You wont have that problem after you do that.
Old Jan 9, 2008 | 09:15 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
are you lowered? i dont see it in your signature.
Old Jan 9, 2008 | 11:38 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Springs being unmatched to the shocks are what causes that. ie your springs are too worn.
Luckily gabriels/monroes and the like give a lifetime warantee, and they normally last a long time on a "normal" car.
Old Jan 9, 2008 | 11:53 AM
SteelTownMadDog's Avatar
Buy Konis and be done with it.
Old Jan 10, 2008 | 08:05 PM
chevy boi's Avatar
Car: 1989 i roc-z28
Engine: 350 tpi l98
ok so they springs are more then likely shot. if i buy a set of bilstine shocks with the wore out springs will they go out quickly also
Old Jan 10, 2008 | 09:00 PM
Sonix's Avatar
Car: 1982 Trans-Am
Yep.
They are high quality shocks, so they will last longer than the cheapies, but their lifespan is drastically shortened when they have to "work" harder to keep up with saggy weak springs.
Get new springs, $80 for moog replacements - done deal.
Old Jan 11, 2008 | 05:08 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Why would you want to match high-quality struts/shocks with 18-year-old springs?
JamesC
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kevyb1973
Aug 24, 2015 04:11 PM
89-S-dime
Aug 12, 2015 11:57 AM
