Which would be better?
Old Jan 17, 2008 | 03:30 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
Would I be better off with my Eibach pro kit and Koni yellows, or one of the Tokico Illumina shock/spring combo kits? Handling comes first, but ride counts for something as well.
Old Jan 17, 2008 | 03:42 PM
Jason89RS's Avatar
Re: Which would be better?
If it was my car, I'd go with the Koni's.
Old Jan 17, 2008 | 06:48 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
See my sig!!
(just get better springs)
Old Jan 17, 2008 | 07:07 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
i think for the money tokico is the way to go since it will be overall about 1/2 the price of the opposition you discussed. just my opinion.
+ i cant remember exact ratings but, the eibachs have an inanse spring rate, i was told the springs with the tokico's were much closer to ws6/iroc springs.
Old Jan 17, 2008 | 07:26 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
They don't have an insane rate. The Prokit is actually softer than the stiffest IROCs and only abou 14 lbs stiffer than the 2nd stiffest.
And if handling comes first, you don't really want a soft spring set. Besides, the KONIs are expensive for a reason. You get what you pay for really applies here.
Old Jan 18, 2008 | 11:46 AM
Engine: tpi 305
I've already got the pro kit on the car, but I hear opinions that Eibach springs suck, etc. Have plain old sensatrac shocks now, but still very happy with the car's handling. Shocks/struts are my next suspension buy and want to try not to screw it up.
Buying Konis alone or the Tokico combo kit will cost roughly the same money.
Old Jan 18, 2008 | 08:27 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I say KONIs. Better shocks. The springs are ok... could do better, you don't know if the Tokicos will be better than what you have.
Old Jan 21, 2008 | 01:37 AM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
I have Koni yellows on my car with Pro-kit springs and absolutely love them..
that is except for the nasty yellow color they are painted. I actually painted them flat black because I couldn't stand it.
Old Jan 21, 2008 | 10:22 AM
Jason89RS's Avatar
LOL that's alot of work for something you can't hardly see...but hey to each his own.
Old Jan 21, 2008 | 10:27 AM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Tokico springs and shocks on my car, very good working combo - no quality issues. I have no experience with the Koni/Ebaich combo, but this setup works just fine.
Old Jan 21, 2008 | 07:05 PM
Car: 88 camaro
Engine: 355
Well you can see the struts and even the rear shocks through my rims. There is alot of stuff that maybe only I can see but I do it for myself. Perfectionist... maybe, but that yellow is disgusting. LOL
Old Jan 21, 2008 | 07:10 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I like the yellow. Easier to show off.
Old Jan 21, 2008 | 08:55 PM
Jason89RS's Avatar
Exactly.... it's your car, so do what you want.
Yea it's not the best color but it is distinctive to those that know.
