Rear Traction Issues
Old Jan 22, 2008 | 09:43 PM
Procat's Avatar
Car: 88 Camaro IROC
Transmission: THM 700R4
Running a 88 I-Roc (4 Speed Auto) and seem to have traction issues.
I have to be super careful starting out other wise I spin the wheels, even when I'm going 20-25 MPH and punch the pedal the wheels spin.
I just got new higher end tires.
It's almost to the point that I want to add weights to the rear of the car inside the back side panels. I'm sure the forum wisdom can talk me out of this crazy idea?
Any advise welcome...
Old Jan 22, 2008 | 09:59 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: Rear Traction Issues
What tires you have? Is the car modded engine-wise?
Old Jan 23, 2008 | 04:29 AM
Procat's Avatar
Car: 88 Camaro IROC
The tires are Toyo Proxes 4. (Brand new)
The engine doesn't have in any visible mods.
Old Jan 23, 2008 | 04:31 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
is it snowing?
Old Jan 23, 2008 | 04:56 PM
Procat's Avatar
Car: 88 Camaro IROC
Well, it isn't snowing or icy... but the been running about 10-20F lately...
I'd be over joyed if this was the problem.
Old Jan 23, 2008 | 07:48 PM
85IrocZ-28's Avatar
Car: 1985 Iroc Z-28
The low temps don't help. The tires run colder and are harder in this weather.
Old Jan 29, 2008 | 04:41 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
When did the problem start? Have you done anything to the car at about the time it has started doing this? Do you drive with a lead foot?
Could it be some bad bushings on the LCA?
Old Jan 29, 2008 | 10:32 PM
86irocterror's Avatar
wait till it gets hot...if the car is stock you will have trouble getting proxes to even break loose....lol do you have have the 15 inch wheels?
Old Jan 30, 2008 | 09:23 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Stock worn out LCA's, Panhard Bar, Torq Arm bushing, no Sub frame connectors....stb, wonderbar...
My car grabs much better after all those upgrades...
Raf
Old Jan 30, 2008 | 12:07 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
Raf
youre car is a tork monster. 350 + tpi= torque= instant gratification.. and youre foots probably a bit heavy too. u may even have an aftermarket cam.
Frozer!!!
Jan 19, 2024 04:55 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mizz0313
Aug 12, 2015 06:45 AM
