Who has a spohn K-member?
Old Feb 15, 2008 | 12:30 PM
BadAz_Iroc's Avatar
I was just looking at the spohn k-member on there sight, it could be the picture but that k-member look like it drops down pretty low, lower then the trans pan, can someone tell me how much clearence do you get using a spohn K-member, i know someone here has one.
Old Feb 15, 2008 | 01:47 PM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
Re: Who has a spohn K-member?
get spohn subframe connectors first if you don't have them already
Old Feb 15, 2008 | 02:24 PM
BadAz_Iroc's Avatar
ok...........but what good is that when i still dont know how much clearence i have, f-bodies are pretty low.
Old Feb 15, 2008 | 02:33 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I agree. But it seems to depend on which tranny it is for. I looked at the one for the th400, and it looks like it drops real low.
I have heard of people having major issues, with dual exhaust routing with them.
Old Feb 15, 2008 | 02:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
He's asking about the k-member, not transmission cross-member.
Old Feb 16, 2008 | 07:47 AM
BadAz_Iroc's Avatar
I guess no one here has a spohn k-memeber, lets me know its not worth getting.
Old Feb 16, 2008 | 11:25 PM
mxcrazed's Avatar
Engine: None
Transmission: none
my bad thats 2x on that mistake but i still think that SFC's should come first if your cause is better handling.
Old Feb 17, 2008 | 09:23 AM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
The guy that did the LS1 swap on my car attempted to use a Spohn Kmember. Needless to say I still have the stock Kmember in my car. The Kmember had some pretty bad allignment issues. There are some guys on the board with em though.
Old Feb 17, 2008 | 10:32 AM
AC's Avatar
AC
Car: Used to drive a camaro
BadAz_Iroc, do a search first...this has been covered pretty extensively. Long story short is some guys apparently had issues with fitment when using the Spohn unit, some had issues with fitment and OEM a-arms, some had fitment issues with spohn a-arms and kmember..others say it is the sweetest thing since sliced bread. Me personally, I don't have either but a friend of mine has both the kmember and front a-arms and he LOVES them.
Old Feb 17, 2008 | 04:06 PM
Dr G's Avatar
I have the Spohn K-member and A-arms with Koni shocks/struts and Eibach lowering springs. Believe me, the clearance between Spohn K member and the ground is not an issue. No matter how 'slammed' your car is.
It's a quality piece of engineering and bolts on with no problems.
Old Feb 19, 2008 | 06:10 AM
FORMULA355TPI's Avatar
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
Ground clearance with the Sphon K frame is actually better, since the diameter of the tubing is much les than the size of the oe crossmember it gives you more room under the engine as well.
Old Feb 21, 2008 | 10:59 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
i got the K-member and A-arms, and it bolted right in no prob, i haven't been able to test it, b/c i'm in iraq and the engine is still out of it, but it defenatly has more clearance all the way around then the stock unit
Old Feb 23, 2008 | 11:16 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
Anyone have any before and after pics of underhood/undercar? Anyone take the time to wiegh both pieces? I was curious what the wieght savings was.
Old Feb 23, 2008 | 11:52 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
20 pounds savings if that
Old Feb 23, 2008 | 11:56 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Are you guessing or did you wiegh both pieces. Also, did you do the A arms? Just curious, as I plan to do the swap
Old Feb 23, 2008 | 02:27 PM
BadAz_Iroc's Avatar
Well......all i want is the k-member, do you have to have all the other parts to make it work.
Old Feb 23, 2008 | 03:28 PM
KJZ28/TA's Avatar
Car: 2002 Camaro
Engine: :(
They did a swap in Camaro Performers If I had a scanner I would post it. They got theres from some other company though. They had a High School Shop class install it because it was that easy.
Old Feb 26, 2008 | 09:48 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
I just wanted to state that I did not have the facts straight. The Kmember that gave him problems on the LS1 install into my 92 GTA was from PA Racing and NOT Spohn. Nobody twisted my arm, I just wanted to add this incase someone does a search someday and reads my first post. Sorry for the passing along of mis-information.
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
luvofjah
Sep 26, 2015 08:28 PM
Mdenz3
Sep 17, 2015 08:36 AM
