What do you think of this look? New wheels
Old Apr 27, 2008 | 03:30 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Here's my new setup, Boyd Junk Yard Dogs with BFG G-Force Sports.
My rears are 17x10 with a 5.75 backspacing. They stick out a little too much for my liking, and I have about a 1/2 inch of clearance between the inner fender and the tire on the front of the tire (if you'd draw a horizontal line from center of rear wheel to door). How much does a rear end move around? Is a half inch of side to side clearance excessive?
Old Apr 27, 2008 | 04:56 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
Re: What do you think of this look? New wheels
very nice
Old Apr 27, 2008 | 05:15 PM
cameron7710's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
i like um they look good
Old Apr 27, 2008 | 11:07 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
Those remind me of the ROH RT wheel. very good looking wheel.
Cheers!!
Old Apr 28, 2008 | 09:44 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I like those. Car looks good.
You can trim the inner wheel well lip for more clearance, but I'd have a auto-body shop do it. I had mine done for more clearance when I had the quater replaced.
Old Apr 28, 2008 | 08:23 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
Those look great,I like the way they look from the rear.
Old Apr 28, 2008 | 09:05 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Considering I'm not a big fan of chrome wheels, they look pretty good.
WOW... big house
Old Apr 28, 2008 | 10:25 PM
Car: '88 Iroc
Well everybody seems to like 'em so far. They're actually polished aluminum. As for the house- not mine. I just live there.
Old Apr 29, 2008 | 09:42 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Very nice set up.
What is the front rim size and bs?
Old Apr 30, 2008 | 09:46 PM
Car: '88 Iroc
Originally Posted by The Project
Very nice set up.
Thanks. The fronts are 17x8 4.5 inch backspacing, or 0mm offset. Same as front Iroc wheels.
Old Apr 30, 2008 | 10:08 PM
dirtywhiteZ28's Avatar
Car: 84' Z28-White/T-Tops
Engine: H code LG4 305
Transmission: TH700R4
Axle/Gears: Stock 3.23
They look great, thats the set I've been wanting for awhile now but just can't get the cash up. I think the only time you have to worry about rear wheel contact is if you catch a bunch of wheel hop trying to burn off some of that expensive rubber all at one time.
Old Apr 30, 2008 | 10:16 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Hey Vortec 350 where do you live in MN?
Old May 1, 2008 | 08:36 PM
Car: '88 Iroc
Rogers
Old May 1, 2008 | 09:39 PM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
Old May 2, 2008 | 08:09 AM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
Nice car and wheels. I'm running 17x10 with 6.25" backspacing. I haven't done any modes to the fender wheels. I have clearance all around but it is tight. I can get my fingers around the rims and the bumpstops.
Old May 3, 2008 | 09:20 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Is that fitment with the stock rear end?
Old May 22, 2008 | 09:56 PM
pondriver's Avatar
Engine: 350 HSR
If that is directed to me. Yes, stock 9 bolt.
Old May 29, 2008 | 11:10 PM
rsrookie's Avatar
Car: 1992 Camaro RS t-top
Engine: 305 Jasper
Yeah dude ,those wheels are a hit. Botchin' stance,too!! I take it you won't be driving it during those harsh Minnesota winters....
Old Aug 15, 2008 | 08:18 PM
bonddav's Avatar
are you using sapcers adaptor or any mods to get them to fit
Old Aug 15, 2008 | 08:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
read the post, no, they will bolt right on, but the clearances are tight
Old Aug 17, 2008 | 04:22 PM
Car: '88 Iroc
That's for damn sure. I wouldn't drive anything but a crappy vehicle in the winter.
Old Aug 17, 2008 | 07:43 PM
bonddav's Avatar
do they rub and are you using spacers
Old Aug 21, 2008 | 05:07 PM
Car: '88 Iroc
No I'm not using spacers. The back wheels had to be made but the fronts are a size and backspacing that are off the shelf. They don't rub, the backs have at least a half inch of clearance at their tightest point.
Old Aug 21, 2008 | 08:59 PM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Wow nice, both the Z28 & the IROC kick a$$. Later.
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
