backspacing and fittment of a 15 x 10 wheel
1 Post
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
i know this has been covered many times, and i have searched, but i have not found one defnitive answer.
is it possible to fit a 10" wide wheel on my camaro without doing any tubbing, mini tubbing, excessive hammering, etc. ?
if so, what would i need as far as backspacing goes and other measurements?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: backspacing and fittment of a 15 x 10 wheel
10" rim, 5.5" backspace.
Does it fit without modifications and hammering? It depends on what size tire you want to put on that rim. Some tires fit with no problems. Others need work.
1 Post
i am thinking DOT slicks (MT ET street's?) what size would work the best? or would something else work better?
Car: 87 Z-28
Engine: 383 HSR w/supercharger, AFR heads
Transmission: 700r4 w/2500 stall
Axle/Gears: 3:73
I'm running 15x10 with 5.5 bs. The tires are Mickey Thompson ET Street Radials 275/60r15. They fit with no rubbing.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i just posted pics of a 91z with 15x10s. 5.5bs. probably on the second page.
I have weld pro stars (15 x 10) with MT 26x11.5x15 ET streets and i didnt have to do any hammering. Its an 82 i dont know if that matters or not. Thats also at 30 psi, dont know about a lower psi yet.
Car: '82 Z28
I was running Hoosier quicktime pro 26x11.50x15's without problems and I've gone up to a 28x9x15 Hoosier slick. They both had about the same section width so no sidewall rubbing.
Car: 02 SS camaro, 92 Z28.
Engine: modded LS1 and built EFI 406
Transmission: 4L60E and Turbo 400 w/brake
Axle/Gears: 12 bolt w/3.73s and 9" w/4.11s
U can run a 28x12.5x15 et street also.
what springs should be used. mine are old and in bad shape. just got the car so looking forward to doing it right. has anyone ever used a wrinkle wall dot tire
i have 1996 rear end on my 1992 camaro and looking to put new rims on and need help im looking at bassett rims right now but need to find out back spacing im just now getting into it and still don't make sense to me 15 x 10 would be nice! with white letter mickey thompson tires
ya just bolt them on!
see they fit no probs 29x13x15 on a 10" rim
bolts right up!
like a glove!
10.275 inch rim with a 6.5 back space...fits like facty
rb85TA
26
09-14-2015 10:29 PM
