any experience summit 1" lowering springs?
Old May 23, 2008 | 11:57 PM
iroc3o5's Avatar
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D720102&N=700+4294925022+115&autoview=sku
these appear to be a very cost effective, good looking set of springs. any one have em heard of em or used em? i also like the fact they lower is 1-1.5" rather than 2" like eibach ect
Old Jun 1, 2008 | 12:50 AM
Subnoizebro's Avatar
Car: 1987 Z28 Camaro
Transmission: 5speed
Axle/Gears: 3.08
Re: any experience summit 1" lowering springs?
I actually bought them beleive it or not and i say for the price they are nice. Much better than the stock springs on my 87 Z28.
Old Jun 1, 2008 | 07:15 AM
iroc3o5's Avatar
would you say your camaro is dramatically lower? i have a hard time getting a floor jack under my car as it is
Old Jun 1, 2008 | 07:31 AM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
yea thats one of the reasons im not gettin them cause i cant get ramps under the front now
Old Jun 1, 2008 | 06:32 PM
eddie jr's Avatar
get some ramp extensions....work real slick. Makes it a lot easier to get on the ramps (safely) if you have a manual tanny too.
Old Jun 1, 2008 | 06:52 PM
ssean92's Avatar
Car: sold
Pics???? of them installed
Old Jun 2, 2008 | 12:08 AM
Axle/Gears: 3.08
Um my camaro sits a lil higher than stock in the first place cuz of our KYB shocks. ive never had problems with the car being to low. the only pic i have of post installation is this one. It was a lil after 630 so not to much sun. The springs have been fully set and ill get a new pic tomorrow for you.
Old Jun 2, 2008 | 12:13 AM
Axle/Gears: 3.08
Ya not very good, sorry guys. Tomorrow ill have it on level pavement and in the light, keep in mind that this is right after the installation of the front and now (2 days later) the springs have been broken in
Old Jun 2, 2008 | 12:15 AM
mike_c's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
Anyone know the spring rates of these?
Old Jun 2, 2008 | 12:19 AM
Axle/Gears: 3.08
Sadly i do not. Summit just says "The progressive-rate springs will lower your vehicle between 1 in. and 1.5 in. depending upon the application."
Thats an exact copy paste of the info on them.
Old Jun 2, 2008 | 05:14 AM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
The stance in that picture looks great. The car is definately lower than stock, maybe not lower than really old stock springs, but...
I am borrowing IROCz85's picture, it shows a better shot of the factory ride height, and my car in my sig too!
Old Jun 2, 2008 | 10:29 AM
zeitgeist's Avatar
I just installed these a few weeks ago. I have to say that they have been a perfect choice for me. Cheap and effective... Ride quality is also much better than it was with the Moog springs I put on less than 2 years ago.
Its the best suspension mods I have done so far. I give these springs 2 thumbs up for the modder on a budget. Also, if you have any problems, Summit will gladly exchange them even after they have been installed. I know from personal experience. I didn't index them as perfectly as I should've (whats an inch or two, right?). Well, they said if I couldn't get the ride height even'd out, they will swap them with a new set no questions.
God I love living less than 20 min from Summit!
Old Jun 2, 2008 | 11:05 AM
zeitgeist's Avatar
And for the record, w/ the moog springs (after break in and after they settled) my ride sat at 28in at the center of each wheel well.
After the swap, my ride sits at 26in measured at the same spot.
Old Jun 2, 2008 | 12:25 PM
iroc3o5's Avatar
what do you mean index springs?
Old Jun 2, 2008 | 01:11 PM
zeitgeist's Avatar
indexing the springs... I had the bottom end of the spring about 1.5 inches outside of the 2 little holes on the A-arm that are used as a reference on where to put the end of the spring.
That little 1.5in difference added nearly 1.75in on the height of the passenger side of the car. Weird, eh?
Old Jun 2, 2008 | 05:41 PM
Engine: LO3
What shocks are you using to control the summit brand springs??
And you said it rode BETTER than the WS6 springs?
Old Jun 3, 2008 | 12:53 AM
Axle/Gears: 3.08
Im not sure about him, but i have KYBs keepin the summit springs in check. i lagged it with the recent pic, but ill have someone take the pic tomorrow. To try and give you some insight on how they've effected me, before the springs i could only take a 90degree right turn at about 35mph with out hearing tire squeal and earlier today i hit the same turn from work at 45ish and it was very confident both in and out of the turn.
Old Jun 6, 2008 | 02:51 PM
daghstdrummer's Avatar
Car: 1986 Z28 Camaro, 2002 Audi A4 (DD)
Engine: 350 .30 over w/bang for buck combo
Axle/Gears: stock for now
from what i can gather Summit springs are actually hotchkis springs w/ the summit logo on them... this is only from comparing pictures not spring rates.. but they look very similar and don't match up with any other springs from eibach or moog
Old Jun 6, 2008 | 03:40 PM
Stevo's Avatar
Car: Pair of 92 Z28s
I heard they were the same as pro-kits. The advertised drop is the same. Sam Strano on ls1tech has used a set and i think he said something about them being the same as pro-kit. I would do a search on there. I think ill be going with a set for my gf's T/A.
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
sailtexas186548
Aug 26, 2015 03:32 PM
