Spohn LCA relocation mounts installed
Old Jun 5, 2008 | 01:13 AM
skinny z's Avatar
FYI
Attached Thumbnails Spohn LCA relocation mounts installed-100_1903.jpg   Spohn LCA relocation mounts installed-100_1904.jpg   Spohn LCA relocation mounts installed-100_1909.jpg
Old Jun 5, 2008 | 01:17 AM
skinny z's Avatar
Re: Spohn LCA relocation mounts installed
More
Attached Thumbnails Spohn LCA relocation mounts installed-100_1907.jpg   Spohn LCA relocation mounts installed-100_1911.jpg
Old Jun 5, 2008 | 02:23 AM
Guest
Guest
Posts: n/a
Nice welds in the first pic.
Old Jun 6, 2008 | 07:51 AM
skinny z's Avatar
Can't take credit.
Tom Britton.
Altered Images.
Angus , Ontario.
Old Jun 10, 2008 | 09:07 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
so how well do they work for you?
Old Jun 10, 2008 | 09:09 PM
kerplunk318's Avatar
yeah how much better do you hook up??
Old Jun 10, 2008 | 09:44 PM
skinny z's Avatar
There's definetly a change in the cars launch attitude. The patch left behind on street tires is much deeper than before and the feeling that the back end is squating is gone. I used the most aggresive setting on the LCA angle as well. Not going to have much chance to enjoy it though. Smoked half the flat hydraulic lifters after a long road trip. I'll need to rebuild before I can get to the track and try them.
Old Jun 10, 2008 | 10:01 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
why the relocation brackets with the stock arms?
if anything, the arm is flexing and not allowing you to use the brackets to the full potential.
Old Jun 10, 2008 | 10:03 PM
skinny z's Avatar
Boxed OEM pieces and poly bushings.
Old Jun 13, 2008 | 09:31 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i put these on my car and no joke, the next time i ran it at the track it pulled the front tires about 5inches off the ground. that was the only thing i changed so i would say they work quite well
Old Jun 15, 2008 | 10:58 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
next on my list-
so much squat and tire spin right now (ever since I put in my 383- go figure)-
thanks to the sticky posters-
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
TheExaminer
Aug 25, 2015 07:34 PM
NBrehm
Aug 5, 2015 07:57 PM
