Need help making my car handle the 383!
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Ok i will be having a 383 put in with 475 hp at crank. I want to build my car first though. so heres what i thought of.
thanks
kevin
- Subframe connectors
- 3:73 posi (already have not installed)
- high performance shift kit
- sway bar kit
- wonder bar
- rear control arms (are these important)
thanks
kevin
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: Need help making my car handle the 383!
aluminum girdle cover for the 10bolt
posi/limited slip
YES, lower control arms with relocation brackets(these take alot of stress when accelerating.. upgrade or at least use poly bushings)
posi/limited slip
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
relocation brackets necessary on the lower control arms? I am installing the subframe connectors, lower control arms, torque arm and front steering subframe connector all from UMI Performance.
Car: 1984 Trans Am
they will help eliminate wheel hop and let your rearend live a little longer..
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
dont expect the rear to live long if you plan on beating it at all.
im not going to be racing a hole lot from a dead stop. Im just going to mabey race on the high way alittle. Then i dont think i will do a hole lot of burn outs tires are to much money. So it will be like what i do now and thats not very bad.
kevin
kevin
Now i like the strut tower brace but will it help alot or should i put that down on the list.
kevin
kevin
Car: 86 Trans Am
the strut bar will help the cars cornering ability by eliminating/controlling the amount of flexing the strut towers do, its a nice addition but by no means a top of the list item at this point
I keep thinking about how much hp! I want to have a bad motor that will run a mid 11 in a 1/4. so do i need that much power? I can get a 400 hp at the crank for 4800 installed. So do you guys think i need that much?
Here the big thing i want to beat the 6.0 GTO's the new GT's and beat the regular vett not the z06.
tell me what you think!
thanks
kevin
thanks
kevin
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
It sounds like your going to have a car similar to mine. With the setup your talking you should be all the cars listed about, if they are close to bone stock. Even the z06 stock runs 12's. I will let you know what I run this weekend, so you have an idea what you may run.
Mitchell
Mitchell
Ya your car is what i think i want but do you think it is to much for an every day driver?
kevin
kevin
Car: 1988 Camaro
Engine: 383 Stroker
I just took a 600 mile trip with it and got 21 mpg!
thats like better than what i get now lol. How much did that cost you if i can ask you that. I am hopeing for it to be 5,800 or less.
thanks
kevin
thanks
kevin
Car: 1988 Camaro
Engine: 383 Stroker
Are you asking about the motor? Just the parts were around 3000. I had a machine shop splay the main, bore, hone and all that fun stuff for a little more dough
Ya the the motor. I was thinking it would be 5,800 with installation at the highest hopefully.
thanks
kevin
thanks
kevin
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
i suggest less power and more work on the car and driver that have to handle it.
on a more helpfull note, perhaps a nitrous system to cut down on the cost of reaching that much hp, thus retaining more streetability.
Why do you think i am seeing if i need to get anymore parts for the car? Then alot of you guys just asume that we cant drive a car that has some power. I drive my dads car and it will still beat my car once its done.
kevin
kevin
I have a 552 hp 385 in my car. I went with a TH350 tranny after going through four 700R4 rebuilds. The 700R's didn't last long. I had a billet servo, kevlar racing bands, borg warner clutches, Precision Industries Vigilante 9" convertor and still lost third and overdrive in my trans. Overdrive was always the first to go out.
I installed southside machine bars and subframe connectors with an eight point cage, but I have a T top car. If you plan on driving the car on the highway a lot, I wouldn't go any higher than a 3.42 or 3.45 if you have a Borg Warner rear with disc brakes. My car has a 3.45 gear and it's cranking almost 6 grand when it crosses the 1/4 mile mark.
If you plan on keeping the 700 tranny, slap a corvette servo in it for some nice firm shifts. I would do this instead of a shift kit. If you plan on baby'n it around, you might get lucky, but I know you won't. You will eventually get bit by the "stomp it" bug, hehe.
Ya man this week my shift kit is goin in with the corvette servo. Then i have 3:73 going in it in two weeks i rarly get on the high way. But the guy thats doing my transmission said their not bad transmmisons till u throw nos at them.
kevin
kevin
Car: 91 RS
Axle/Gears: 3.45
joeblue, are you serious? you have a 383 stroker and it only runs 12.5's? hm maybe im just under estimating but i figured that you could get at least in the 11's with a 383.
why dont you just drop the motor in yourself? save you some money
and then take it in for a tune if oyu need to.
and then take it in for a tune if oyu need to. Senior Member
Car: 1988 Camaro
Engine: 383 Stroker
Its really bad off the line, I can't get a real good run in. I know that my stall converter is to low for my motor also. I will run again in a month with a higher stall converter and bigger rear tires. I should be in the upper 11's by then.
Car: 91 RS
Axle/Gears: 3.45
oh ok i see i figured there was a catch to it, hey i wasnt trying to bash you or anything its a bad @ss set up, way better than mine i just thought maybe 11's. im glad i dont have to deal with a torque converter, sounds like a pain in the @ss
