front torque arm bolts 1 or 2??
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
i noticed some noises when i was pushing my car out of the driveway and i looked under the car and the front of the torque arm appears to be moving. My buddy said my bushings are shot, i looked under there but they look good but it appears i only have 1 bolt. there is a spot for the other bolt it looks like but it doesn't look like I would be able to get it in there at all. here are some pics thanks
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: front torque arm bolts 1 or 2??
i though there were 3? but yes you are missing at least one and should replace it.
Car: '89 IROC-Z
Engine: 355
how would you get the bolt in though, i'd have to take the whole thing out right?
Car: '89 IROC-Z
Engine: 355
anyone have any pics with the bolts in??? would be helpful thanks
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
You can remove the crossmember so the tranny tilts down, to give you more room. I would just remove the 4 bolts that hold the tail housing (Transmission extension case) on. remove drive shaft, and pull that whole assembly out. So might as well replace the bushing for the trq arm while it's out.
Reassemble
here is similar thread https://www.thirdgen.org/forums/susp...m-slip-up.html
Reassemble
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Its a pain to do. The bushing is a 2 piece bushing that sandwiches the front of the torque arm. You have to pull the DS and drop the end of the tranny till you can slide out that bracket (long bolt). I had to do it last year, took me a while to figure it out.
That's why you should just remove the whole tail housing from the tranny. Make's it so much easier. All you really have to do is remove the drive shaft, 4 bolts, then disconnect the speedo cable or the wires to the VSS, whichever you have. Remove the 2 bolts at on the bracket by the exhaust, then remove the 4 bolts that hold the tail housing to the trans.
Car: '89 IROC-Z
Engine: 355
but if i just took the one bolt out shouldn't the torque arm come out then?
The trq arm itself just slides in and out of the bushing. No need to undo any of the bolts, except the 2 long bolts on the rear. I am talking (and what I thought you were asking) about, is the "clamshell", the part that holds the bushing.
Terrell351
Jun 13, 2021 01:13 PM
ambainb
Apr 25, 2016 09:21 PM
