spohn torque arm adjustment.
Old Aug 10, 2008 | 10:23 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Weird question which is confusing me is that it says to get the pinion angle you need to take the driveshaft angle and subtract it from the torque arm angle.
If lets say the driveshaft is 0 and the torqe arm is -1 is that 0- (-1) which is positive?
Im not sure but my car is spinning horrificly off the line. I have drag shocks in the back mickey thompsons dr's lca and the torque arm. If its the way i just said i think im actually a positive 2* on my pinion angle which will cause the spin right?
Im trying to understand how could i be spinning halfway through second
Old Aug 10, 2008 | 11:13 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: spohn torque arm adjustment.
Here is a vid off of BMR website will show how to set it, http://www.bmrtvonline.com/video_detail.php?mId=3788
Old Aug 11, 2008 | 01:36 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
so actually im at a -2* then. so i have no idea why i spin so horrific
only other things are my lca relocation brackets arent in. i dont know how much that helps.
Then there is my tire pressure. I have it at 21 psi which probably i need to go down to like 17psi
BTW great vid tony
Old Aug 11, 2008 | 06:00 AM
Tony89GTA's Avatar
Car: 89 GTA
What's your 60" at?
Old Aug 11, 2008 | 12:10 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
You just need those relocators in there. I did pretty well all the suspesion work to get my car to hook for 9's. I put the 305 back in running 14.4's and it now hooks on street tires pulling 1.8 60' times, let alone the 1.44 60' the good motor has done.
Old Aug 11, 2008 | 01:57 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Ya i just put them in we will see what happens this friday
Old Aug 11, 2008 | 05:38 PM
Tony89GTA's Avatar
Car: 89 GTA
Want to go over your suspension setup kind of curious what you need to do to hook with street tires on a 1.8 60"?
Old Aug 11, 2008 | 08:34 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
I have it all at: http://timeslips.fbody.com/fast82Z I was amazed also when I did that last year.
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
a car with not much power and a low stall.
lol really idk im tryint to get this stupid thing hookin hard
EDIT: i have almost all that you do except the front drag springs and shocks and the sway bar.
Old Aug 11, 2008 | 09:00 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
What size are your tires? I run mine at 15-15.5psi, which turns out to be around 14-14.5psi cold. The tires have a noticable bulge to them, as in looking low on air.
Old Aug 12, 2008 | 01:35 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
i have 275/40/17 in the back. the pressure was at 21psi but im gonna try like 16-18
92rsvortec350
19
Oct 9, 2015 09:39 AM
Nervous2
Oct 8, 2015 10:53 PM
luvofjah
Sep 26, 2015 08:28 PM
Nick McCardle
Sep 10, 2015 08:36 PM
