C6 wheels at four corners (19x10) would they fit?
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
I got a set of C6 staggered for my '88 Bird, no tires yet, but wanted to know if the rear 19x10's would fit up front. If they would fit I may pick up a couple more rears, car will be dropped 2" also. Later.
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
Re: C6 wheels at four corners (19x10) would they fit?
I dont think it will fit very well. Id stick with 18x8.5 up front.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you can put them on the front, though they will have to stick out a bit more and you may loose some steering angle. A wide tire on the front will also track on the road and make the car a handful to drive as a DD on public roads. 9.5 is the max people seem to put on a 3rd gen.
I have seen 11's on the front, but with fender mods and im sure steering issues.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9 3.00
you will have steering issues and require a spacer thats near 3 inches long
I have 19x10's on the rear and when i tryed to fit them on the front, it would be a very tight fit.
you may beable to get away with proper spacer size and a skinny 275 tire. i run 295's so it just aint gonna happen without sacrificing lots of clearance. On turns ona lowered car you'd bottom the fender out on the tire
I have 19x10's on the rear and when i tryed to fit them on the front, it would be a very tight fit.you may beable to get away with proper spacer size and a skinny 275 tire. i run 295's so it just aint gonna happen without sacrificing lots of clearance. On turns ona lowered car you'd bottom the fender out on the tire
Car: 89`RS
Axle/Gears: 2,72
Hey guys,
I have 10x18 with 285/35/18 front and rear and they fit.
Iīm in process of lowering my car right now with an Eibach Sportline Kit and Koni yellow Shocks. Lowering Front 1,6" and rear 1,3".
I think itīs finished tomorrow, then I can tell you if they fit right, or rub somewhere. I can take pics if required???
So if you want to use 19" you only have to use 275 or 285/30/19, this will be the same tire amount than 285/35/18.
Rob
Rob
Car: '91 TA vert
Engine: turboLSx
I've actually wondered the same thing for quite awhile. However, I've just been too lazy to try and fit the rears on the front.
Ideally, I'd like to run a 285 all around.
Ideally, I'd like to run a 285 all around. Trending Topics
Car: 89`RS
Axle/Gears: 2,72
Ok it took me a little longer, but finally its done.
Yes they rub the inner fender, to clear that, you have to make the steering angle a little bit smaller.
Let me know what you think, here we go...
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
Those wheels look nice,what brand are they,what backspacing and size spacers did you use?
Car: 89`RS
Axle/Gears: 2,72
These are American Racing wheels (special edition "Dale Earnhard jr") called Killer Chrome
they are 10x18 with +41 offset and I use 30mm spacers front and rear.
Greetz Rob
Greetz Rob
Car: 86 Trans Am
so for the wider wheels you sacrificed turning radius? not sure i would go for that. they do look sweet though
Car: 89`RS
Axle/Gears: 2,72
Its not a daily driver, only weekends when itīs not raining.
And here it rains a lot
The car is insuranced from April to October, since April I drove it 400mls...
You understand the steering angle is not important for me!
ambainb
Apr 25, 2016 09:21 PM
kah992
Aug 19, 2015 02:55 PM
