need a measurement for a sway bar
Old Oct 16, 2008 | 04:34 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
i was going to replace my front struts and springs and found out that the sway bar is rubbing on the passenger side and i dont know if its bent or just outta line so if someone has an old sway bar laying around that you know is straight could you please measure it from hole to hole (the hole for the sway bar link) and let me know or can you tell me where to find this info? thanks
Old Oct 17, 2008 | 09:43 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Re: need a measurement for a sway bar
Clamping a tape measure at one end, I get 43 7/8".
Old Oct 17, 2008 | 10:30 PM
Brennan's Avatar
thank you where did you take the measurement from? middle of hole or outside edge?
Old Oct 19, 2008 | 09:47 PM
Flip 2's Avatar
Engine: C5 LS1
middle to middle- (that way I could clamp one end of the tape to the sway bar)
Old Oct 20, 2008 | 04:36 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
For the front I got 43 3/4" going from center of endlink to center of endlink.
Old Oct 20, 2008 | 05:37 PM
Brennan's Avatar
center to center i got 43 3/8" looks like i got a bent sway bar oh well time for an upgrade i suppose
Old Oct 21, 2008 | 05:12 PM
Car: 1987 IROC-Z
Transmission: TH350
The swaybar that I measured is a 36mm bar that I actually have for sale if your interested...
Old Oct 21, 2008 | 05:15 PM
Brennan's Avatar
i would if i wasnt in canada and whats the stock bar diameter?
Old Oct 21, 2008 | 06:08 PM
Car: 1987 IROC-Z
Transmission: TH350
Many different sizes came stock. It depends on what kind of car you have and what some of the RPO codes are for your vehicle.
for the front, I think there was a 32 hollow, 34 hollow, 36 hollow, and a 34 solid (ultra rare... only on factory race cars)
for the rear, there was a 19, 21, 23, and a 24 (all solid). There is also an aftermarket 1" solid (25.4mm) bar that you can buy.
Old Oct 21, 2008 | 06:32 PM
Brennan's Avatar
cool i always thought mine was solid but im assuming not lol its a 84 z28 any ideas on what ive got?
Old Oct 21, 2008 | 07:00 PM
Car: 1987 IROC-Z
Transmission: TH350
If it is hollow there will be two little holes near the endlinks. I think your vehicle would have 34/21, but I'm not sure... someone else can chime in here.
Old Oct 21, 2008 | 07:10 PM
Brennan's Avatar
no holes by endlinks and measures in at 1 1/4" dont know what that is in mm 32-ish i think
Old Oct 21, 2008 | 08:28 PM
Car: 1987 IROC-Z
Transmission: TH350
Yes, that's 32mm.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
