Front end bushings?
Old Oct 21, 2008 | 01:50 PM
British Rich's Avatar
Car: 92 Camaro RS
Axle/Gears: Stock
Front end bushings?
So I have play in my tie rods and center-link etc.
There is no way I can afford to replace everything anytime soon.
SURELY new bushings will tighten it all up though right?
(even if not completely solving the problem)
I am aware I'll be doubling the labor when I eventually replace the rods and link, but I'll do it myself so it's not too bad.
Old Oct 21, 2008 | 03:15 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Front end bushings?
What bushings would those be?
JamesC
Old Oct 21, 2008 | 04:34 PM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
JamesC
good question...
You need to just fix the tie rod ends... and check your pitman arms also...
Old Oct 21, 2008 | 04:44 PM
Car: 92 Camaro RS
Axle/Gears: Stock
all of the bushings where each of the bars "link".
"just" fix?
(I don't have the money to replace much more than bushings - I have already spent a bunch on ball joints, rotors, pads,bearing, sway bushings/links and controlarm bushings)
Old Oct 21, 2008 | 05:36 PM
JamesC's Avatar
There are no bushings where the bars link.
JamesC
Old Oct 21, 2008 | 05:48 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
JamesC
there are no bushings to replace, just the tie rod ends. Also check your idler arm and pitman arm, may also want a new center link.. these arn't exactly expensive parts and are simple to replace. You could do the work yourself and have it professionally aligned after. Simple stuff.
Old Oct 21, 2008 | 06:28 PM
JamesC's Avatar
The pitman arm isn't a wear piece, so unless it's damaged in some manner, you can probably discount it.
JamesC
Old Oct 21, 2008 | 06:35 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
yeah dude those are pretty cheap parts and if you install em your self should only run you 50-100 bucks
Old Oct 21, 2008 | 07:00 PM
Car: 92 Camaro RS
Axle/Gears: Stock
ok, I assumed there were bushings at all the links (hard to see with all the grime on there without really getting into it)
PS - "only" $100 is still a lot a week after doing ball joints, and then "just" $70 for rotors, "just" $60, for bearings/seals, "just" $130 to replace a tire, "just" $50 for LCA bushings.....oh and of course "just" $50 for ad-hoc tools I didn't have.
I don't mean to sound ungrateful for the replies but I have already said twice that I am broke so I have no choice but to do whatever is the minimum required for the time being. I know these parts aren't expensive but sh*t adds up REALLY quickly!!!
Thanks for the input guys.
Old Oct 21, 2008 | 07:03 PM
Brennan's Avatar
have you tried a junk yard the parts will be cheap and should last long enough till you can afford new stuff
Old Oct 21, 2008 | 08:07 PM
89RsPower!'s Avatar
JamesC
right, the centerlink where it connects to the pitman is, it's been a while since I had my front end apart. As far as not having the money, If I were you I'd simply wait until I had the money, this isn't an area to skimp. Sure you could throw used parts on but it will still need an alignment so instead of paying for two alignments (unless you have access to an alignment rack) I'd wait until you have the 50-100 bucks to spare and do it right the first time. The best way to do it cheap would be to replace just what needs to be replaced, if the centerlink is ok leave it, if you only need outer tie rods just get outers, if you just need inners get inners, etc.
Old Oct 21, 2008 | 08:17 PM
Car: 92 Camaro RS
Axle/Gears: Stock
I agree but I REALLY need an alignment already but tha is pointless until I fix the slack grrrrrrrrrrrr....
Gonna mean more new tires sooner rather than later too, just sucks how the front end is so "all or nothing".
Too late now but if i knew what I know now a few weeks ago I would have just bought the whole re-build kit and done it all at once
Old Oct 21, 2008 | 08:32 PM
89RsPower!'s Avatar
I hear ya man, being broke sucks. My Iroc is sitting ever since I started my 350 swap, I ran out of money. All I need is a water pump, belt, and a few sensors..
Old Oct 21, 2008 | 08:35 PM
Car: 92 Camaro RS
Axle/Gears: Stock
Amen man
"just" another $100 or two is a lot of money when you have already run out. oh well, it does make it all the sweeter when u get it done.
Old Oct 21, 2008 | 09:02 PM
89RsPower!'s Avatar
especially when you've been laid off recently and have a ton of bills piling up..
Old Oct 21, 2008 | 09:08 PM
Car: 92 Camaro RS
Axle/Gears: Stock
ouch
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
TheExaminer
Aug 25, 2015 07:34 PM
