Pics of STB and Carb or TBI
Old Nov 2, 2008 | 09:42 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
I am thinking that a STB will be purchased in this next year as I continually inprove and upgrade my car.
I have a Carb and an Open element air cleaner. I also have a spare HO air cleaner that I may put on at shows.
I wanted to see if anyone would be kind enough to post up some pics of theirs with a StrutTowerBrace and either the TBI or Carb applications.
Also opinions on how much it reduced cowl flex, any info if it gets in the way of things you do like maintenence and any other info.
THX, Michel
Old Nov 2, 2008 | 09:53 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: Pics of STB and Carb or TBI
I'm sure it will make a huge difference in the stiffness of the car. If your concerned about accessibility, get one that can be unbolted easily like the Edelbrock piece.
Old Nov 2, 2008 | 10:11 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
My UMI stb did help alot IMO with the front end stiffness. Im sure all the STBs are pretty much the same for stiffining up the car, 3 points even more. You'll be happy with whatever one you get.
p.s. thanks for the t-top bag Mike!! Looks like new!
Old Nov 2, 2008 | 11:03 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Click on links in sig for more pics
Old Nov 3, 2008 | 06:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check mine out in my Car Details below. Worthwhile.
JamesC
Old Nov 3, 2008 | 06:28 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
crappy pic, but its there
edelbrock 3 pt, like krisb410, but with solid mounts
Old Nov 3, 2008 | 07:33 PM
krisb410's Avatar
Yeah, that's an old pic, but shows the STB best.
Old Nov 4, 2008 | 03:17 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Here's mine, I love the damn thing. I've had it on the car for 4 years now.
Old Nov 4, 2008 | 04:29 PM
Mikz86TA's Avatar
RobertFrank - cool idea on the aircleaner lid. I have an Open with a Flow-Thru top and also posess a HO assembly. I never thought of combining the 2.
89ROC-Z - No problem. Glad you got the bag you wanted.
Thanks for the pics and opinions. Those look like thicker tubing than I thought they would be. I didnt see the removable base or solid base option. But i see 86TA has solid mounts. Was that just something you did or did I miss something?
I dont have alot of underhood clutter. I have the 86 multi-belt pullies and each item has its own bracket. Thus I only have an Alt and PS Pump. No Smog pump or any related equipment, no AC or related hoses, no AIR Injection on the SLP Headers I have, etc. So it looks like it wont interfere with much under my hood.
After I get the underhood area repainted in my re-fresh and restore quest, I am going to get one of these.
Prob an Edel since they are the only one I see now for Carb.TBI.
THX again, Michel
Old Nov 4, 2008 | 04:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
I didnt like the mounts that edelcrock provided, the seemed way too tall, and being able to pivot on the bolt would still allow the strut towers to flex upward and little. I cut the STB, made the solid mounts, it also allowed my to lower it a little in the front, and you cant see in the pic, but where it mounts to the fire wall, i have mine reversed, the plate bolted under the cowl lip and the tubing sitting up, providing a little more clearance on my Dizzy. I will have to grab a pic of it tonight.
Old Nov 5, 2008 | 04:09 PM
Mikz86TA's Avatar
OK cool.
You got a late model brake resivior IC. Why is that?
Where did you get the Alum Coolant overflow tank? That in really sharp!
Old Nov 5, 2008 | 04:32 PM
Demon355's Avatar
I'll have pics up of mine soon. I have the Edelbrock one the same as most guys that have posted already. What I would like to do also is change the mounts to solid like 86TA did. Nice job btw, I want to see the pics of the cowl.
On a side note, I love those mounting brackets for your alt and pwr steering robertfrank. Is there a kit or did you buy those individually?
Old Nov 5, 2008 | 07:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
in robertfranks, the alt mount looks just like my March mid mount bracket, and the PS looks like a matching piece.
Pics of my cowl?
Originally Posted by Mikz86TA
OK cool.
Its a master cylinder and reservoir form an ls1 car. Its just a better design, looks cleaner that the stocker, and i upgraded to c5 front brakes and 4th gen rear brakes, so i needed a master more designed for a disc/disc car that my stock disc/drum one.
the coolant can is from Canton
Old Nov 5, 2008 | 08:13 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
http://www.geocities.com/MotorCity/7...ts/engine1.jpg
Here's an old old old pic of mine with the stock dual snorkel....
Old Nov 5, 2008 | 11:50 PM
Mikz86TA's Avatar
Demon - Looks like the March Low-mount alt setup. I have the March std mount bracket like that. The PS bracket is also availible. I got the PS March pulley but not the bracket yet..yet =)
86TA - THX, I now remember seeng that tank. Pricey but very cool. That master res looks like th one on my S10. Just curious.
Paul - THX, I was wondering how the fitment with the HO intake was. I got a spare HO intake I plan on using if I can for shows.
Old Nov 6, 2008 | 07:03 AM
Demon355's Avatar
Yes where the STB mounts to the cowl, you said you modified that as well. I've been looking to replace my serp setup I have currently with a March pulley kit but what my Alt to mount low like the PS pump. You guys have exactly what I wanted and I'm wondering if you have any part numbers? Do they sell the brackets separately or do you get them with the pullies? Are they underdrive like the Power/Amp series?
Old Nov 6, 2008 | 11:08 AM
Mikz86TA's Avatar
I bought seperately the Alt bracket kit, the 3-pc Pulley kit, the Alt pulley 'hat', tha PS OEM replacement pulley and then also did stainless mounting hardware. I havent bought the PS bracket yet. But they are all availible seperately.
He has the Low-Mount alt bracket. which is a seperate part number.
My pulleys are the stock replacement 86. Which had 2 v-belts and 1 multi-grove belt. It was kind of a weird year setup.
If you are deleting the air, smog and junk.....then you would probably just convert to the std 'HotRod' type pulley kit. March makes many different ones. They also sell packages with custom brackets and pulleys ready to install. But that gets pricey.
http://www.marchperf.com/
Old Nov 6, 2008 | 11:27 AM
krisb410's Avatar
Wow, this thread needs to go
Old Nov 6, 2008 | 04:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
its still mostly on topic, just a little tangent
Old Nov 6, 2008 | 04:46 PM
Mikz86TA's Avatar
Im OK with it as is.
If anyone else has any other types of STBs on their rides, then post them up. Akways looking for differences.
Old Nov 7, 2008 | 06:45 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
i had one but i took it out, its still laying around the garage
Old Nov 7, 2008 | 07:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
here are the pics i promised
a different angle, where you can see the back of the STB
detail of the solid mounts
the cowl mount, its unmodified, but the STB is built upside-down, to help with dizzy clearance and i think it had another purpose, but i forget what it was
and now that i look at the pics, i see that the hood is rubbing a little on the STB at the back there. No biggie.
Old Nov 7, 2008 | 07:25 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Here's my homegrown one:
Old Nov 7, 2008 | 11:53 PM
Car: 1987 IROC-Z
Transmission: TH350
Some paint would make the bar look better Lo-tec.
Old Nov 8, 2008 | 01:16 PM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Transmission: TH700R4 Raptor
Axle/Gears: 2,7x -> 3.00 or 3.50
I thought you could not use it with the dual snorkel setup, did you run into some problems with it?
Old Nov 8, 2008 | 06:56 PM
paul_huryk's Avatar
It is meant for the dual snorkel. The problem is some cars have a/c bracket interference... My A/C is long gone.
Old Nov 8, 2008 | 11:19 PM
Mikz86TA's Avatar
What kind? You selling it?
Old Dec 11, 2008 | 03:00 PM
dpmalibu's Avatar
does anybody have the part # for the 3 pt STB? Did you guys say that was made by Edelbrock?
Old Dec 11, 2008 | 03:30 PM
JamesC's Avatar
Edelbrock 5227. Check Summit.
JamesC
Old Dec 11, 2008 | 04:14 PM
krisb410's Avatar
That looks like it is installed upsidedown!!!!! No wonder why it rubs the hood.
Old Dec 11, 2008 | 04:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i know its upside down, i did it on purpose. Installed the other way it was sitting right on the dizzy and thats not gonna work, so i went this way. Its just a little rub, nothing major, only in one small spot about an inch long.
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
cstrobel65
Aug 15, 2015 10:19 AM
