Firehawk Tire Question / Already Searched
Old Nov 8, 2008 | 04:57 AM
fadetoblack's Avatar
Car: 1990 Formula
Engine: 383 Stroker
What is the largest tire that will fit on the Ronal Firehawk Wheels (17 x 9.5) on the REAR of a 1990 Formula without causing problems? I know that Firehawks originally had 275's on them. Thanks!
BTW .... I installed an Eibach Pro-Kit set of springs on my car. So it should sit about 1" lower than stock.
Old Nov 11, 2008 | 06:48 AM
Car: 1990 Formula
Engine: 383 Stroker
Re: Firehawk Tire Question / Already Searched
Anybody???????
Old Nov 11, 2008 | 07:33 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Well, I got 275-40-17 with it lowered on Eobach ProKit springs.
I could look tomorrow and give you a judgement on how mych more space there is or get a pic.
Old Nov 12, 2008 | 07:10 AM
Car: 1990 Formula
Engine: 383 Stroker
Thanks! That would be awesome.
Old Nov 13, 2008 | 02:58 PM
Mikz86TA's Avatar
Hey, sorry I took so long to get back.
Heres some pics of the gaps.
Between the fender lip and tire is a good deal even with the Eibach ProKit lowering springs. The tire does sit inside the lip, so its hard to judge on my 275-40s what effects a wider tire would have. Plus the Falkens I have angle in spightly. I know some times have more of a 'shoulder'.
The gap between the inside top of the tire and the upper part of the fender well (closeup pic inside) is about 1". So if your tire is alot wider (which may not fit on a 9.5" wide rim) than it may scrub in there.
Clearance at the LCA, also shouldnt be an issue with the 9.5" wide rim as shown in the one pic.
I do also have Spohn LCA Relocation brackets. So my LCAs hang lower and more next to the tire edge as shown.
Hope these help.
Old Nov 13, 2008 | 03:47 PM
Car: 1990 Formula
Engine: 383 Stroker
Hope these help.
That is EXACTLY what I needed. I have Spohn LCA Relocation brackets as well. I hadn't even thought about that. Looks like 275's are the way to go.
I can't tell you how much I appreciate your help and the extent you went to on my behalf.
BTW ....... PM sent.
Old Nov 13, 2008 | 03:58 PM
Mikz86TA's Avatar
No problem. Always glad to help anyone I can.
Michel
Old Nov 13, 2008 | 04:26 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
OMG! Thank you Mikz86TA! Now do you have some pictures of the 17x9.5 with 275 tires on the front? If so, your pictures just got me a set of 17x9.5 wheels for free!
Old Nov 13, 2008 | 06:53 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Dude, I've got both. Why haven't you asked?
You'll need front and rear 2 inch spacers to run my wheels though. Any 4th gen offset wheels need them. There are a few wheels that don't, but they are hard to find. However, if you have a 4th gen rear end (like mine) you won't need the rear spacers.
Old Nov 14, 2008 | 01:14 AM
Mikz86TA's Avatar
Yeah! What pics do you need. I got Eibach ProKit up there too. I can get u fenderwell and profile. Just request it, Ill get it for yall.
Old Nov 15, 2008 | 08:53 PM
Car: 1987 IROC-Z
Transmission: TH350
I just need pictures showing the clearances for the wheels. If I can prove to my uncle that there is enough room (without mods of any kind) he said he would buy me 17x9.5 wheels. So... I guess there are enough pictures proving the backs fit without any issues, but do you have any showing the clearance around the front wheel? Pics of it at full lock left and right? and how about how far they stick out in relation to the fender lips?
Thanks a bunch!
Mike
Old Nov 15, 2008 | 09:56 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
That one is at full lock left. It rubs just a little, but that was due to the allignment. I just (like five minutes ago) took the 17s off the car and put the 16s on, or I'd take some for you. The front actually tuck in very nicely, though. Here is a few shots of them:
and from the rear...
Old Nov 16, 2008 | 12:45 PM
Mikz86TA's Avatar
Ill get some for you 'Geek also.
Did yours come with 16s or 15s stock? Mine came with 15s stock. Theres a diff between the 'stops' on the 2 stock sizes. I think the 15 stop allows for a tad more turn and thus causes a slight rub on the swaybar where it curves. But I also have a 34mm front bar.
Also there was an early and late design inner fender sheild (plastic part). At the back of it, mine has a slight rub because mines the early design. The later design has a recessed section where the tire comes next to it in full lock. I think thats how it goes.
Try to get pics today for ya.
Michel
Old Nov 16, 2008 | 05:37 PM
Car: 1987 IROC-Z
Transmission: TH350
Michel
My car came with the 16's from the factory, so it has the WS steering box with the smaller turning radius and larger bump stops. It's an 87, but I don't know what the cut off for the inner fender difference is. I do have the 36mm front bar but I don't think it will be an issue.
Thanks,
Mike
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
