Question about Iroc Rims
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
I'll be swapping my 15" RS rims out with a set of 88-90 Iroc's. Will I need spacers....I'm guessing they would be for the rear, right? I have a 91 RS with drum brakes. Thanks.
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: Question about Iroc Rims
You don't need spacers because the wheels are built with the correct backspacing. You may experience rubbing at full lock since your steering stops are not in the correct place but then again, how often are you really at full lock...
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/auto...acer+iroc+drum
If you hadn't considered it, your speedo will be off with the new wheels unless the IROC's are 15's.
JamesC
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
No, this will not happen if your overall tire diameter stays the same. Just make sure you get the same overall tire diameter/height (the tire numbers will be different if the rims are a different size) and you'll be just fine.
True, of course. I was thinking of OE tires on OE rims. Out of curiosity, jb, are these IROC rims 15's or 16's?
JamesC
JamesC
Car: 1991 RS
Engine: 383 stroker
They're 16's...I also need one more if anyone knows where I can get one. Someone had 3 rims in good condition for sale with decent tires on 2 of the rims for $250. They were a local pickup so I thought it was a pretty good deal.
thanks!
thanks!
Car: 93 Formula,88 T/A,01 WS6
Engine: 93 LT1,88TPI305,01 LS1
Transmission: 93 700R4,88 700R4,01 T56
Axle/Gears: 93 3:73's,88 3:42,01 3:40
I think I have one IROC wheel left.... do you need front or rear??
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
I haven't taken any picks of the car in months, but it doesn't look any different than an IROC exept the ground effects are different. This is the 4th set of rims I've tried on the car. The last set were 18s that I think looked bitchen, but I got 0 traction with those, so I swapped to the IROCs. Several people I know said it looks better with the IROCs. I know it hooks better and drag radials for 16s are a lot cheaper than with the 18s.
Car: 1991 RS
Engine: 383 stroker
Alright...I found a front rim in NY for $100. Probably could have found a better deal but I don't have any patience. Anyway, the two rears have 255/50/16's. What should I go with up front? 245's?? Thanks and merry Christmas!
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
My 88 IROC came with the 16 inch wheels and rear disc brakes and I never had a problem with fitment till I replaced and upgraded my entire suspension. There are some reports on the board that, like mine, when all the factory slop is gone, the front's can rub the inner fender. I just put 1/4 inch spacers on the front which solved it PLUS the wheel looks better closer to the fenderwell arch. I'm going to add some to the rear to help visually fill the space. Some people even run the front IROC 16's on the rear, which pushes them out even further. Nitro
mustangman65_79
Aug 11, 2015 03:17 PM
