Will these winter tires fit my 16x8 wheels?
Old Jan 2, 2009 | 06:30 PM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Transmission: 700r4 built
Axle/Gears: 3.42 Locker
I am not positive on if these tires will fit my soft 8 cragar 16x8 wheels. thanks. http://www.discounttiredirect.com/di...sw=true&cs=225
Old Jan 2, 2009 | 06:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Will these winter tires fit my 16x8 wheels?
like a glove
Old Jan 2, 2009 | 06:46 PM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Thank you very much. I went to mavis discount tire today and said to the guy behind the counter "you have any winter tires that fit 16x8 wheels?" He said "no" and then I come home and find ten tires that fit on my wheels on mavis discount tire's website.... Now I have to go back there and show him how to use a computer
You have helped me a lot, thank you
Old Jan 2, 2009 | 06:59 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I would think a 60 series sidewall would make the speedometer reading closer to correct. Stock sizes were 235/55 and 245/50s, so I think that 225/60s would be better. Might be wrong though.
Most tire places employ morons. My ex took her car (a 95 Eclipse) to have it alligned and tires replaced. Well, she had 18x6.5s on it from the previous owner. They order her something like 245/40R18s.... I tell her they're too wide for the rim (for the rim and the car) and will probably rub. She tells them and they tell her it'll work. Guess what- they put them on the car, and send them back. Similar incident occured when I ordered BFG g-Force KDWs and end up with g-Force Sports. At least the size was correct.
Old Jan 2, 2009 | 07:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the tires diameter is 25.7, which is stock
Old Jan 2, 2009 | 07:11 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Oh. Didn't see that on there. Just trying to be helpful
Old Jan 2, 2009 | 07:43 PM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
okay so I should go with a 55 treadwall because it is stock size?
I never changed the speedo gear when I put in 3.42's....so I have been driving by feel..I will get to it eventually.
Oh man sorry to hear that about the tires. I would rap the guy who wouldn't listen to you in those tires and roll him down a hill.
Old Jan 2, 2009 | 08:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
stock size is fine, no real reason to go larger. the 60 series should be about 3/4" taller, which will still fit, but might start to rub in the front when turning.
Old Jan 2, 2009 | 08:40 PM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Okay cool.
now I get to go to mavis tomorrow and push the salesman aside and order myself tires.
Thank you everyone
Old Jan 2, 2009 | 08:50 PM
Stephen's Avatar
Car: 87 GTA
NOOOOOO....Don't do it!!
A 225 on a 8" wheel? Yes, it'll "fit" but why do it? That stretches it to the max. 245s would be a MUCH better choice.
I don't think you'd be very happy with the looks OR performance of those skinny tires.
Old Jan 2, 2009 | 10:02 PM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
okay okay I wont get them. I just wasn't aware there was a 245 winter tire. I found some 235 60 16 snow tires. Here is the list of them
http://www.mavistire.com/ProductCart/pc/_shopbysize.asp
Old Jan 3, 2009 | 11:05 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
It's a winter tire. You don't want wide tires for winter tires. See if the manufacture says they are ok with 225s on a 8" wheel. If so, you'll have to put up with the looks and the smaller tread area. 235s might be a better choice when you factor in those criteria. That being said, I use 245s on my winter wheels (Bridgestone G009s) and 275s on my summer wheels (BFG g-Force Sports).
Old Jan 5, 2009 | 03:20 PM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Alright I finally got my winter tires together. But when I picked up my wheels with the snow tires on them they put a 205 55 16 on one of them! I didn't even know a 205 could fit on a 16x8. It looked like a donut tire. So I had them put on the right size tire, 225. Then I get home jack up the car and both tires can only go on the driver side...They are uni-directional snow tires so I had to go back and tell them they put one of the tires on backwards..Then I finally got home and put them on. Sorry about the dirt, I just drove through a lot of slush going to and from Mavis...
Old Jan 5, 2009 | 04:40 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Don't go back there, please.
Old Jan 5, 2009 | 05:11 PM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
hahahaha. Pretty much, there terminated.
Old Jan 5, 2009 | 06:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
must be a pretty lousy shop to install 1 different tire, and one backwards and let it out the door that way. I wouldn't go back
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
