squeeks
Old Feb 10, 2009 | 12:39 AM
Kagen's Avatar
squeeks
When I'm driving my car and from outside it is very squeeky and makes a lot of noises as it goes by. What cheap things can I replace to reduce these noises. Should I just start replacing bushings and stuff?
Old Feb 10, 2009 | 01:01 AM
snowman383's Avatar
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
Re: squeeks
get some 3 in one oil and put on bushing's to re moisten them that would be a cheap start
Old Feb 10, 2009 | 06:31 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: squeeks
You don't mention year, make and model, which is always helpful. At any rate, since your car could be 20+ years old, you'll need an improvement plan (to save money in the long run): Is the car simply going to be a daily driver or are you going to throw in performance parts?
JamesC
Old Feb 10, 2009 | 12:29 PM
Kagen's Avatar
Re: squeeks
its a 87 iroc. It'll be daily driven until I can find a different car to drive.
Old Feb 10, 2009 | 01:15 PM
myroc86's Avatar
Car: 86 Camaro
Engine: 350 LT1
Re: squeeks
Turn the radio up, really cheap fix lol. Jamesc is right 20+ years old bushings and things are worn. If its gonna be a daily just replace with stock components, unless you have HP plans.
Old Feb 10, 2009 | 01:28 PM
Kagen's Avatar
Re: squeeks
I'm leaving the engine in it stock but I'm gonna be building up a 350 outside of it. Where can I find the bushings at?
Old Feb 10, 2009 | 01:37 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: squeeks
If you got crappy handleing and poor steering you should just replace the front end with a kit that will come with most of the bushings, then get the ones for the rears. If your changing out the bushings and the stock parts are on like the idler arm, centerlink, swaybar, tie rods, ball joins, Lower Control arm bushings ect.
Can free up lost horsepower, improve handling, and fairly cheap.
Wana check calipers to, they have a bad tendency to squeak,
warped pullies will make some bad sounds coming from the bay
old wheel bearings
door stripping,
rip out the dash put padding everywhere if it shakes like mine "which im doing so so very soon !"
Old Feb 11, 2009 | 10:57 AM
1 Quick T/A's Avatar
Car: 92 Firebird
Axle/Gears: 3:42
Re: squeeks
What I do is when I have the car up in the air, oil change or whatever, take spray oil, like WD-40, and hose down all the bushings from all angles.
Also havn't done this, but if you replace the bushings cover them with powdered graphite before installed, I hear it's the chit.
Old Feb 11, 2009 | 08:57 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: squeeks
Only bad thing about spraying wd40 every is you make everything sticky and road grim will bid up fast
Get a greese gun 10$ and some silicone grease and lube it the right way
Old Feb 11, 2009 | 09:05 PM
myroc86's Avatar
Car: 86 Camaro
Engine: 350 LT1
Re: squeeks
haha remember now, not too much lube
Old Feb 13, 2009 | 06:26 AM
Kagen's Avatar
Re: squeeks
The lube helped the squeeks. But it still leaves this other wierd sound. When I engage the clutch sometimes when its in gear it will make a loud clunking sound. It doesn't do it all the time, and never when its not in gear, also if you shift really slow it wont do it
Old Feb 13, 2009 | 06:32 AM
JamesC's Avatar
Re: squeeks
Check the trans mount. Should it be bad, replace with poly.
JamesC
xxx3man`
Sep 23, 2015 10:37 PM
89_305TransAm
Aug 21, 2003 07:22 PM
FRDH8R
May 16, 2003 12:54 AM
Conv389drv
Apr 25, 2001 03:19 PM
