oohhh my head hurts!!!
Car: 89 iroc
Engine: zz383/compcam/gmpp intake/holley770
Transmission: 700r4 w/all the goodies
Axle/Gears: 4th gen 3:23w/powertrax
Bare with me kinda long. I ordered 18" A.R.E. iroc replica's only to find out with the 4th gen rear they hang out past the fender. 0mm offset and they dont make a diff. offset for the rear.
So I have decided to go with the C6 rims and for 2 days I have tried to search and read and measure and search and read somemore but to no avail. I'm CONFUSED!!! I want 18" front and rear. And I don't know what to get. -56mm or 58mm, will 9.5" work on the front blah blah blah..... HEADACHE!!! Please help me. I found the ones on ebay for $620 and don't understand which ones to order. I know I will need a spacer up front. But do I need a spacer with the rear? Really I have searched and read so much I just can't comprehend all this. Any help would be greatly appreciated!!!
So I have decided to go with the C6 rims and for 2 days I have tried to search and read and measure and search and read somemore but to no avail. I'm CONFUSED!!! I want 18" front and rear. And I don't know what to get. -56mm or 58mm, will 9.5" work on the front blah blah blah..... HEADACHE!!! Please help me. I found the ones on ebay for $620 and don't understand which ones to order. I know I will need a spacer up front. But do I need a spacer with the rear? Really I have searched and read so much I just can't comprehend all this. Any help would be greatly appreciated!!! Thread Starter
Car: 89 iroc
Re: oohhh my head hurts!!!
bump. Please help!!!
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
This been covered a million times, you do a search yet? I have 17x9.5 +56mm with my 4th gen rear, 2in spacers up front
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I don't want to get into a dispute, but why spacers and not a more wicked offset?
Edit: I went through about 50 arguments and 10 days of reading about fitment and the correct offsets on my Z31 boards. We dislike spacers over there...ha ha. My head hurt too.
Guest
Posts: n/a
Lets look at the facts-
Aftermarket IROC wheels will fit on stock rear end. THey are 0mm offset and 8" wide. They stick out 16mm wider than the factory 16mm positive offset wheel, but fit nicely under the lip still and give that slightly wider stance by 16mm outward or roughly 5/8". 4" + 1/4" lip is 4.25 backspacing on an 8" wheel.
Stock "rear" factory IROC wheel has a 4.9" offset and sits inward 16mm more than the aftermarket ones you bought. Factory "Front" are 0 offset and again are 4.25 backspacing.
you now have a 4th gen rear that is 4" wider overall or 2" wider per side.
1 inch = 25.4mm so you now need a positive offset wheel with at least 51mm more. At most being another 16mm back to stock at 67mm offset.
So there is your range- 51 to 67mm offset. Lower the better bringing the tire lip outward to the fender lip. on the rear. So now you add those figures to the 4.25" original and you now have 6.25 to 6.9 offest on an 8" wheel.
You need to buy an 8" wheel with 6.25 to 6.75 range of back spacing Lower the # the wider the car will look. I would personally buy the 6.25.
Now, add 9.5" wide wheels. We DO NOT want to change the outer lip where the wheel fits under the fender lip so we add the 1.5" extra of the wider wheel to the inner fenderwell. Here's where it gets a little confusing for most. The 8" wheel was 0 offset, SO.... if you had 4.25 backspacing, you have 4.25 front spacing also. The whole wheel is 8.5 wide with the wheel lips.
Gotta go, I will finish later. Sorry
Car: 89 iroc
I would love to do a nice offset but the C6 rims are only 56 or 58 offsets. I cannot fit what I want (18" irocs) so I have to go to the next option. I.E. C6's. Therefor I need spacers in the front. I have read all of the posts on this but I keep getting confused. I think with 56 or 58mm offset front and rear and LS1 front brakes with 2" spacer it will be ok. I'm just not sure if it's 56 or 58. I really do appreciate all those who took there time to help me and hopefully I can figure this out before monday.
Car: 89' IROC-Z
Engine: LO3
WE NEED THIS ON OUR SITE.
Its nice to be in 2 types of car worlds.
Z31 Wheel Fitment Site
NOTE: In each section some people state direct fit, which isn't FLUSH but is direct fit. They fit under the correct fender lip. But if you roll the fenders (technically opening them up to their actual size), that is how you attain TRUE FLUSH. Also factor in lowering a car and camber settings/changes when driving. Also key points in flush fitment.
Guest
Posts: n/a
There are slight descrepencies in factory wheel lip thicknesses that can vary up to a 1/4" in wheel overall width that will vary the final outcome.
The 58 mm offset on the 4th gen rear will sit you out 12mm outer the fenderlip. If I recall, Zepher had that same setup and his wheels looked slightly outward of stock with his 4th gen rear and I believe ZR1 wheels 9.5" wide.
Guest
Posts: n/a
http://www.cardomain.com/ride/2224542
Oh yeah, I forgot, rear fenders are rolled, and the front spacer is 2 1/4 inch, not 2 inch. They actually fit better with the 4th gen rear than with the 3rd gen rear with 2 inch spacers. IIRC, the last picture, I just put on the wheels on the passenger side for a test fit.
Car: 89' IROC-Z
Engine: LO3
Nice fitment but you need better pictures kris, showing it. Looks good though.
92projectcamaro
Jan 18, 2016 08:00 AM
