failing at changing steering box.....help
Old Mar 6, 2009 | 11:24 AM
thebufenator's Avatar
Car: Firebird - Camaro
Engine: 2.8L - 6.3L
Axle/Gears: 3.42 - 3.23
It took me forever to remove the old steering box.....
I have the new one sitting in the engine bay, and I cant get the stupid steering shaft on to the steering box. its too freaking tight. and there is no way to get is lose or wider.....
Is there a trick to this? Its positioned in a way that negates using brute force....
Old Mar 6, 2009 | 02:34 PM
Guest
Guest
Posts: n/a
Re: failing at changing steering box.....help
Take the bolt out of the splined end and spread the shaft end using a prybar or a large standard end screwdriver-(just like you would spread the post of battery cables to get them ontot he battery post.)
Old Mar 6, 2009 | 03:07 PM
Engine: 2.8L - 6.3L
Yeah I finally got it all put back together.
I am experiancing something weird when driving though.
when the wheels are centered, it takes some effort to turn the car. once I get it turning past a certain point, it turns really easily.
IT feels like a geometry problem.
Anyone experiance this?
Old Mar 6, 2009 | 03:13 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Where did you get the box? Did you adjust it? Sounds like the over center sector lash adjustment is set too tight. Precision tools are suggested for proper adjustment.
Old Mar 6, 2009 | 03:39 PM
Engine: 2.8L - 6.3L
I did not adjust it. Bought it used from a member here who claimed it was in perfect shape.
How is the lash adjusted?
Old Mar 6, 2009 | 06:02 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Is it equal in both directions? You usually need an alignment after changing a steering box.
Old Mar 6, 2009 | 06:15 PM
Engine: 2.8L - 6.3L
I fooled with the lash and it is better.
I do need an alignment though, the steering wheel is off center.
Old Mar 8, 2009 | 04:29 PM
Engine: 2.8L - 6.3L
Alright, so right now when I am driving down the road, road conditions do not change the direction the car is driving. Meaning, if I put the car in a sharp turn, it wont auto-correct.......it just keeps going in circles. I have to supply a descent amount of force to reverse a turn. It just doesn't feel right.
Does this sound like a gearbox or pump problem?
Old Mar 9, 2009 | 10:00 AM
dan68rs's Avatar
Car: 89 formula
Engine: tpi 350
Axle/Gears: 95 z 3.42
Im having close to the same trouble, it is hard to turn close to center, i have tried with the front wheels off the ground and loosened the gear mesh adjuster to make sure that wasnt to tight but still real tight at center, they guy that i bought the car from had changed it and said it was a racing steering box but im not sure what it came out of. he had to use the flaming river steering shaft to connect the steering wheel.
I was wondering the same thing about mine being possible bad pump. I think the only way to know is to test with guages or change the pump.
Old Mar 9, 2009 | 11:07 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Not the pump. Either the box needs to be adjusted correctly or you have some other problem in the steering linkage. If it returned fine before the box swap, take off the box and properly set the adjuster plug and overcenter set screw. There's a tech article on montecarloss boards on adjusting these.
Old Mar 9, 2009 | 11:18 AM
Engine: 2.8L - 6.3L
Hmm.......looks like I'm going to remove the box and reset those.
I was adjusting the over center in the car, and it started getting better about returning to center, but not before I started getting slop in the steering
Old Mar 9, 2009 | 12:20 PM
naf's Avatar
naf
If you've replaced a 4 turn or low effort box with a performance, high effort box it may not return to center like you're used to.
The most likely cause of tight steering is ball joints. If you're not certain that the problem is in the box you may want to check them and the rest of the linkage. Easiest on an alignment rack where the wheels can be turned by hand with the suspension loaded at the wheels. If you check them at home, load the suspension at the a-arm so the struts aren't fully extended.
You can try to adjust the input plug with the box on the vehicle. I've never done it but I've thought now and again that I may try it that way next time.
Old Mar 9, 2009 | 12:25 PM
Engine: 2.8L - 6.3L
It doesn't return to center at all. Adjusting the over center on the car made it easier to turn the wheel at center, but it still resists returning to center. I continued loosening it, but it started getting slop in the steering. Atleast it felt like it.
Amillionoh7
May 24, 2020 08:01 AM
Out-Cast
Mar 22, 2019 09:39 PM
deracer
Apr 11, 2016 12:04 AM
wild1
Aug 27, 2015 09:01 AM
Bryan F
Aug 27, 2015 07:28 AM
