suspension over haul
Old Mar 9, 2009 | 11:50 PM
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
i need alot of help here i need to replaces everything on my car because it missing or to messed up ( brought a project car) i need a k-member a-arms etc etc.. what company should i go with and what good stock vs after market i am not worry about price i am going to buy parts over time and i want the best for my car i want it to last me forever.. and i need to re do the rear also what do you guys think ???? ideas
Old Mar 10, 2009 | 08:44 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: suspension over haul
Try reading this. Should answer some questions.
Old Mar 10, 2009 | 11:34 AM
UMI Sales's Avatar
Hello
I see that you are looking for some info on some suspension parts. I just wanted to leave you know that UMI Performance is a option for you. We offer A-Arms and Rear End Suspension Parts such as Torque Arms, Upper and Lower Control Arms, Lower Control Arm Relocation Brackets, Below is a link to show you what all we have to offer! If you have any other questions feel free to ask and I will be glad to help.
http://www.umiperformance.com/82-92fbody
Brad
Old Mar 11, 2009 | 01:06 AM
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
i dont plan on racing my car i want a nice smooth ride should i go with tubular stuff? or should i look for a parts car? i really dont have the room at all and i rather buy new stuff and start fresh
Old Mar 11, 2009 | 10:01 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Tubular linkages won't have alot of bearing on your ride as much as it will cornering performance. What bushings you choose would have the most effect.
Old Mar 11, 2009 | 05:54 PM
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
what type of brushing do you recomend
Old Mar 11, 2009 | 06:00 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by BigJon88
i dont plan on racing my car i want a nice smooth ride...
Rubber for the most part, though you could replace the sway bar bushings and end links with poly without noticeable harshness.
JamesC
Old Mar 11, 2009 | 09:41 PM
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
what places would u order them at? and if you had to redo your whole front end what would you buy? i am new to this and would like some ideas
Old Mar 12, 2009 | 06:31 AM
JamesC's Avatar
http://www.spohn.net/shop/1982-1992-...sion-Steering/
JamesC
Old Mar 12, 2009 | 08:25 AM
a1990camarors's Avatar
Car: 1990 rs 1992 z28 1995 jeep
Engine: no engine, 383stroker, inline 6 4.0
Transmission: none, t5, auto
personally id buy a front end rebuild kit. keep the stock k-member i havent seen one that overly impresses me yet besides bmr's. if your not racing id get a set of stock a-arms with new bushing probably rubber if your not racing. if you plan on racing in the future i would get the umi a-arms i like them alot and get the sway bar set. if you ever get really into handling your best bang for buck will be shocks and tires.
Old Mar 12, 2009 | 08:37 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
The best a-arm bushings (between rubber and poly) would be the DelALum from Global west. Probably worth looking into if you are keeping stock arms.
As for sway bars, I'd look around and local junk yards and see what you can come up with. The aftermarket bars are fine, but you can get used GM bars at a fraction of the cost.
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
