spring kit v.s. coilovers
Ok yet again the newby is striking with a vengeance on the probably over posted questions, so sorry again. I am looking at getting into road racing in the next year or so and I was wondering what would be better, a good spring kit like eibach? or would it be worth it to save up some money and go with a coilover suspension?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: spring kit v.s. coilovers
it depends how "into" road racing your getting. If its a weekend auto-x type deal with a pretty much stock car, a prokit would be a good start. Dont forget that you also need a very good set of shocks/struts. Koni yellows are a good choice, at about700bux, and good tires.
If you really have the need to an adjustable spring setup, Ground Control weightjacks are better for autox that coilovers. Coil-overs will limit you front tire size considerably.
This also depends on what class you plan to race in and what mods that class allows.
Car: 87 GTA
Ground Control over coil-overs.
Coil-overs are good for drag racing. They limit your front tire width, which you certainly don't want for a corner carving car.
Car: 86 Trans Am
you can fit a 275 on the front with coil-overs on a 9.5" wheel, but they sit a little too far out for my taste.
Car: 87 GTA
Car: 86 Trans Am
yea, they have to have 5.5" of back spacing, and it will be close to the spring, and flush, if not just a hair outside the fender.
A guy in the local car club runs that setup, and like i said, its just a little too far out for my taste.
Car: 86 Trans Am
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
