exhaust crushing
Old May 29, 2009 | 07:53 PM
S10GUY's Avatar
Car: VR6 jetta for commuting
Engine: VR6
Transmission: 5spd ZF lsd
Axle/Gears: ?
exhaust crushing
i installed eibach sportlines in my 84Z, I also have a dynomax 3" mid pipe as part of my xhaust. when i hit moderate bumps, panhard bar is bangin into the xhaust denting it. all the hangers are in place on the xhaust and i cant get it any closer to the body. any suggestions ?
Old May 29, 2009 | 08:02 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: exhaust crushing
In a stock style exhaust setup, the panhard bar cannot, in anyway, contact the exhaust. Its not possible, it would hit the upper panhard brace first.
Pics?
Old May 29, 2009 | 08:39 PM
Stephen's Avatar
Car: 87 GTA
Something is bent.....OR.....Something else is doing the banging your hearing
And/Or your rear shocks might be out & allowing whatever banging it is, that you are hearing.
Old May 29, 2009 | 08:43 PM
S10GUY's Avatar
Engine: VR6
Axle/Gears: ?
hmm ill get under it tomorrow and check around. is it possible the axle tube is crushing the pipe? i didnt install the exhaust it came on the car. maybe it was banged up before. butill look tomorrow and see what i find
Old May 29, 2009 | 08:52 PM
Stephen's Avatar
Car: 87 GTA
If your rear shocks are shot, yeah.
But they should bottom out or the tires hit the fender wells first, before the axle does.....If the exhaust is up as high as it should be.
Old May 29, 2009 | 10:16 PM
hellrazor's Avatar
Car: 82 Camaro Lots of mods
Engine: Blown 355
Axle/Gears: 3:73
You need the modified panhard brace it is for lowered 3rd gen with 3inch exhaust, it gives more clearence for the 3 inch pipe to come over the rearend.
Old May 29, 2009 | 10:18 PM
Stephen's Avatar
Car: 87 GTA
My GTA has 3" exhaust & the stock brace & never has hit even once.
No...A modified Panhard Bar brace is NOT needed.
Old May 30, 2009 | 05:27 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
no, that part is for a totally different purpose. It provides extra clearance for dual 3" or large single exhausts, 3.5" or larger. Not needed fot a single 3", and for that matter, a single 4" will fit over the factory upperpanhard.
Old May 30, 2009 | 06:17 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
You guys that say the panhard bar cannot hit the exhaust have never seen my car. Mine is crushed in about half an inch to a full inch. Maybe it's not in the right spot or something. Who knows
Old May 30, 2009 | 08:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i have never seen your car, but i can guarantee you that the panhard bar cannot hit the exhaust, its impossible, unless you have removed the upper panhard brace and have a single 5" or larger exhaust or, have a hacked together setup that runs between the upper panhard support and the panhard bar. Perhaps a pic would shed some light on this matter
and since there was some confusion over my last post, the only thing the upper panhard relocation bar does is provide extra clearance. Its not needed for a single exhaust, even 4". Its mainly for a dual setup, though it will give you move room to fit the larger single exhaust setups more comfortably.
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
david068513
Sep 18, 2015 10:36 AM
Bob88GTA
Sep 10, 2015 09:07 PM
