has anybody run with no rear sway bar?
Old Jul 31, 2009 | 05:12 PM
73duster's Avatar
I just installed a 12 bolt rear in the car and found i can't use the stock sway bar. Can i use the car without one? I've never used a rear sway bar in any of my other cars, but these were always 70's mopars. I also put in eibach pro kit springs with koni sport shocks and struts.
Old Jul 31, 2009 | 05:36 PM
1988-305-tbi's Avatar
Re: has anybody run with no rear sway bar?
of coarse you can use the car without a swaybar, its just gonna handle crappy, why can't you use the swaybar? are the axle tubes a different size than factory? whats the issue?
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
your handling will suffer greatly. Buy a new set of mounts for the 3" tubes and reconnect the bar.
Old Jul 31, 2009 | 06:27 PM
84imsa's Avatar
Car: 1984 Camaro
Engine: 327
Transmission: TH700-R4
Axle/Gears: 7.5" 3.23 Posi
A rear sway bar reduces understeer/increases oversteer. Without it, your car will tend to plow in high speed turns. It is safe to drive without a rear sway bar on an F-body although handling suffers.
If you decide to install an aftermarket rear sway bar, you will be much happier with the car.
Cheers!
Old Aug 2, 2009 | 12:35 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Do you have different size axle tubes, or is the bar hitting the center section? You will either need differnet size clamps, or wll have to add a spacer under the axle clamps for clearance.
You Camaro will likely handle like one of the 70's Mopars without a rear bar. It will be driveable, but not like a Camaro should handle.
Old Aug 2, 2009 | 12:50 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Some Berlinettas came without one, BUT the front sway bar was a different size. I didn't feel comfortable with the way it handled as it was and upgraded it.
Old Aug 3, 2009 | 01:27 PM
Shagwell's Avatar
Car: projects.......
To add to the handling issues that have been noted, the rear bar also does a lot for traction and torque steer. - You can get larger U-bolts to fit larger tubes, and spacers can be added between the tubes and the mounts to gain clearance around the housing.
Old Aug 3, 2009 | 03:39 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I have the Strange 12 bolt in my car and had no problem using a stock sway bar with the factory rear end brackets. I'm running the 18mm bar as the car was over steering with the 21mm and larger ones when on heavy throttle. As the 12 bolt is heavier than the factory rears, you will experience oversteer, so you might want to get a smaller rear bar (or a firmer front one).
Old Aug 12, 2009 | 03:17 PM
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
i actually have somethien to say!!! i recently went to the scca regonal/national road race in here in oklahoma and there were some third gens without one. i talked to a guy and he doesnt use one. things it defeats the purpose. using a big frnt tho.(this is at nationals! so they know?
Old Aug 12, 2009 | 04:20 PM
so they were running no rear bar, but a big front bar?
Old Aug 12, 2009 | 04:28 PM
Car: 02wrx/88 rs
yes i believe so. he said i dont run one i think it defeats the purpose and i think he said into a turn it just tried to slide and just didnt work right. if im not mistaken he used a modified 1LE front.
it looked like he cut it off at the turns and splined it then attached a flat peice of alm to it. ill try to get a pic for help with this. he said something about having to modify the ends because they did not move enough stock? said the bolts couldnt take it or somethig that part made no since
Old Aug 12, 2009 | 04:41 PM
Car: 02wrx/88 rs
http://hallettracing.net/gallery/album132/90_AS
[IMG]file:///C:/DOCUME%7E1/COMPAQ%7E1/LOCALS%7E1/Temp/moz-screenshot-1.jpg[/IMG]
[IMG]file:///C:/DOCUME%7E1/COMPAQ%7E1/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]belive the yellow no 90 and red bird 09 didnt. i talked to a guy i cant find. try to get the webside to the sponsor on the back of bird and u may find more info
btw most cars here ran 12 bolt
Old Aug 12, 2009 | 05:56 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
you need to upload those as attachments so we can see them...
we dont have access to your temp folder lol.
Old Aug 12, 2009 | 09:16 PM
Car: 02wrx/88 rs
try that website its the website to a track here
Old Aug 12, 2009 | 09:18 PM
Car: 02wrx/88 rs
http://hallettracing.net/gallery/album132/09_AS
Old Aug 12, 2009 | 09:25 PM
Car: 02wrx/88 rs
http://www.1speedway.com/Swaybar_Arms.htm
splined with something like this on the ends
Old Aug 13, 2009 | 09:08 AM
bsmtech's Avatar
We only disconnect the sway bars in the rain on a road course otherwise make it work for the vehicle handling benefits
Old Aug 13, 2009 | 10:09 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
thats still a sway bar, its just a different style.
The splined piece acts as a torsion bar and the levers on the end allow adjustment of preload.
Old Aug 13, 2009 | 12:49 PM
73duster's Avatar
thanks for the replies. It's a moot point now because i've ordered a bmr 22mm rear sway bar and mount kit.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
z28addict8490
Aug 7, 2015 08:48 PM
