Spohn Del-Sphere Pivot Joint
Old Aug 4, 2009 | 07:49 PM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Came across this the other day while looking at Spohn suspension parts:
http://www.spohn.net/shop/Del-Sphere...d-Threads.html
Its a curiosity to me. It sounds good, but quite a few people that I've talked to are a bit skeptical of it. What do you all think?
Old Aug 4, 2009 | 11:02 PM
87350IROC's Avatar
Car: 87' IROC
Re: Spohn Del-Sphere Pivot Joint
I posted a thread about this a few weeks ago and didn't get any good responses. In any case, I'm going with del-sphere joints when I start ordering suspension components this fall. They seem like a great design, and I have confidence that Spohn wouldn't offer these if they weren't any good. Maybe call Spohn and see what they have to say?
Old Aug 4, 2009 | 11:08 PM
Pew's Avatar
Pew
Car: 90 camaro
Engine: 355
Transmission: t10
Axle/Gears: 9" with 4.88's
there good joint we have been installing them for years there very strong joints and easy to take apart and rebuild. The only down side of them you need to keep them greased very well as they have a tendency of rustin and locking up.
Old Aug 4, 2009 | 11:29 PM
87350IROC's Avatar
Car: 87' IROC
You sure you're talking about the right thing? These are not the same as all metal heim joints. And they just came out. Check the link.
Old Aug 5, 2009 | 04:36 AM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
There will be maintenance!
They have just minimized it. If you install it, it is best to check it every so often.
Old Aug 5, 2009 | 05:18 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Look s similar to J &M Eng. LCA joints...
Old Aug 5, 2009 | 10:36 AM
87350IROC's Avatar
Car: 87' IROC
Agreed J91, the J&M poly ball was probably their inspiration. However I think these should work a little better since its a metal ball on delrin instead of poly on poly. Should be much less bind. Also the Spohn arms are adjustable, and the del-sphere ends are replaceable and rebuildable. Also, you can get these ends on LCA, Pandard Rod, Torque Arm, A-arms.
Old Aug 5, 2009 | 01:00 PM
Guest
Guest
Posts: n/a
Not hardly, The original joint like this was the Johnny Joint by Currie Enterprizes (you know- Currie 9" rearends).
I spoke to Steve Spohn over the phone about these a few years ago and he was asking me what I knew about delrin and its durability as well as maintinance/noise, etc. He was getting some to try and experiment machining with to develop his own version of the Johnny joint for performance use, not offraod articulation Currie uses then in rock crawling competition.
These are great joints, I highly recommend them
Old Aug 5, 2009 | 07:14 PM
Pew's Avatar
Pew
Car: 90 camaro
Engine: 355
Transmission: t10
I know what a heim joint is trust me they arnt new i build rock crawlers for a living along with building suspention systems rock crawlers have benn using these kind of joints for a long time.
Old Aug 5, 2009 | 08:32 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Yeah, they come out with these after I get neck deep the Johnny Joint mess lol. I think I may order these and just write the Johnny Joints off as an $80 loss.
Old Aug 6, 2009 | 10:44 AM
87350IROC's Avatar
Car: 87' IROC
Relax Pew, just trying to make sure you didn't make a simple mistake. I never said you didn't know what a heim joint is.
So how have you been installing Spohn Del-Sphere joints for years when they just came out? Or have you been using similar joints? Like Johnny joints? While they are similar they are not the same. Johnny joints allow for greater articulation than Spohn's joints, which of course doesn't matter for us. Also I believe Johnny joints use a urethane bushing while Spohn uses delrin. Delrin should require less frequent lubrication than urethane.
Old Aug 6, 2009 | 04:31 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
this is a great idea.
delrin is one of those materials that should be used a lot more often than it is
you can do nearly anything with it and it has such great properties.
Old Aug 6, 2009 | 04:44 PM
87350IROC's Avatar
Car: 87' IROC
Hey, if any of you guys are looking to buy the Spohn Del Sphere stuff, be sure to get in on the Hawks Group Purchase on the Group Purchases forum.
Old Aug 6, 2009 | 07:01 PM
Pew's Avatar
Pew
Car: 90 camaro
Engine: 355
Transmission: t10
nope same joint spohn did not create these joint there metal ball delrin surrounds same joint rock krawler suspentions and full throttle suspentions have been using them for years. You need to keep them greased so the inner ball dosent rust because then it chews up the delrin and causes premature joint wear and you have to rebuild them more frequently.
Old Aug 6, 2009 | 07:32 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
What happened?
Old Aug 6, 2009 | 07:56 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
the ball is not going to rust if it is made of stainless steel...
Old Aug 6, 2009 | 08:22 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Originally Posted by krisb410
What happened?
I bought one and it didn't fit because I have 1/2 bolts and not 7/16 (which are the stardard sized bolt centers with the 2" ends), so I ordered the 1/2 bolt centers. It was about $80 all together with shipping. Might just get the Spohn joints since I can't find the right sized joints with the 1/2 bolt centers.
Old Aug 6, 2009 | 09:04 PM
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
The ball is forged 4140 chrome moly. However, the surface of the ball is so smooth that there are no sites for nucleation to take place.
Old Aug 6, 2009 | 09:13 PM
87350IROC's Avatar
Car: 87' IROC
Cool. Thanks for the info.
Old Aug 7, 2009 | 12:37 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
They don't look like they have a huge amount of surface area on the bushings but the fact that they are adjustable for preload on the bushing as well as serviceable is really nice. I may have to pick up a set after the rod ends on my LCA's and PHB get worn out.
Somebody is making rear shock mounts for corvettes this way too, I really hope this tread continues to the point that you can buy universal parts to put in your own housing.
Old Aug 7, 2009 | 01:50 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Kind of like: A 1" round del-rin bushing will fit all these parts 1.2.3.4.5.6.7.8.9 on these cars 1.2.3.4.5.6.7.8.9.
I'd like to hear a little bit more about these, as compared to polyurethane, polygraphite and solid metal to metal contacts. What each would be best suited for (Auto-X, Drift, Track, Drag, Street) and so on and so forth...
Thanks guys.
Old Aug 7, 2009 | 03:35 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
the only place metal to metal is typically used is in the a-arm "bushings" in a circle track type car.
rubber gives lots of deflection and vibration damping, steel/delrin give none.
polyurethane and polygraphite bearings are essentially the same thing and give some but not as much as rubber and are more forgiving than metal to metal.
rod ends are used when zero deflection is desired on a part that articulates in more than one axis.
the poly ball is basically a rebuildable rod end with a few very important tweaks
Old Aug 7, 2009 | 03:51 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
^^Nice, thanks, well said.
Ed1LE
Sep 30, 2018 09:14 AM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Drone358
Sep 28, 2015 04:55 PM
