Axle Spline count om my 91 Z28??
Old Aug 12, 2009 | 09:03 PM
daytonayellaz's Avatar
Car: 91 Z28
Engine: LB9
Transmission: 5-Speed
Axle/Gears: 10-Bolt 3:42 Posi
Ok guys.... Im a newbie here and this is my first 3rd gen camaro and I will probably be asking a lot of questions and hanging out here soaking it all up.
So here is one for the rear axle experts....My 91 Z has the factory 10 bolt 3:08 posi rear. What is the sline count on these axles??
While your at it does anyone know the sline count on a 99 firebird 10-bolt with 3:42 posi??
Reason Im asking..... I was going to swap this 99 rear into my 91. But after I drove 2 hours to the salvage yard to get I noticed one of the axle tubes looks bent a little. So....I want to put the posi unit and gears in my 91 housing and re-use my original. axles. Thanks for all your help on this so far!!
Travis
Old Aug 12, 2009 | 09:10 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Axle Spline count om my 91 Z28??
both are 28 spline, provided the rear in you car is origional and nobody ever swapped it
Old Aug 12, 2009 | 09:27 PM
Car: 91 Z28
Engine: LB9
Awesome! This is good news.
The 99 rear also has disk brakes that I need to figure out how to swap to my rear.
Thanks for the quick reply!
Old Aug 12, 2009 | 09:49 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
As for strength, there's no difference between your 91 and the 99. The 99 is a bit wider.
You can pull the posi and gears out of the 99 and put them into your 91 with no problems. The axles themselves won't interchange because of the length difference.
//<86TA>\\'s Avatar
Car: 86 Trans Am
your stock rear has drums or discs?
Its really not that hard to swap the ls1 rear brakes onto a drum rear, i did it with my old 10 bolt. There is a tech article on the home page in the tech section.
Old Aug 12, 2009 | 10:21 PM
Car: 91 Z28
Engine: LB9
My stock 91 rear has drums.
I would like to remove the posi and gears and the disk brakes from the 99 and put them in/on my 91 rear housing and use my stock axles. This will work or not?
I read the article on here on the brake swap.. Seems easy enough.
Old Aug 13, 2009 | 07:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
More general info that may prove useful at some point:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Aug 13, 2009 | 07:37 AM
Car: 91 Z28
Engine: LB9
JamesC
Great info in that link, Thanks James! Im still trying to find my way around the site. Ive been a first gen owner for 25 years and know these cars pretty well.
First time 3rd gen owner and loving it. Just a new learning curve on a few things with these cars.
Im still a little puzzled with just 1 thing.....I will try and ask this as simple as I know how. Lets say the only thing Im going to use from the 99 rear is the carrrier and gears. If I take the entire posi carrier and gears from the 99 rear......install it in my stok 91 Z rear....will my stock 91 Z axles slide back in and C-clips fasten back on ???
Thanks for all the help and patience with me everyone!! I promise to try not to be a pain in the a**
Old Aug 13, 2009 | 07:50 AM
JamesC's Avatar
As long as the 91 has 28-spline axles, which it should, I see no obvious reason why your plan won't work.
JamesC
Old Aug 13, 2009 | 08:14 AM
Car: 91 Z28
Engine: LB9
JamesC
Great! I am going to move forward with this then. Thank you!
I did read the brake swap write up on here as well and will be taking the disks off the rear as well and putting them on mine.
My original plan before discovering the 99 rear was bent, was to put the whole rear in the car and get some deeper back space wheels. Now Im just going to keep my rear under the car and upgrade it and keep my stock wheels.
Thanks again to all who took the time to help me out. I will be a regular here now, so see ya around
Nick McCardle
Sep 10, 2015 08:36 PM
scottmoyer
Sep 7, 2015 07:06 PM
dbrochard
Sep 7, 2015 09:41 AM
rudolphschenker
Sep 4, 2015 02:41 AM
