86 IROC is too low
Old Sep 22, 2009 | 05:03 PM
BUTTE's Avatar
86 IROC is too low
Ok my car's exhaust is a couple of inches at best from the street. I have 16 inch wheels with 245-50-16 tires all around that are gettin pretty worn. What would be the least expensive way to get another 1 1/2". I could go with new taller tires since I need them anyway but I'm not sure how much taller I can get without rubbing. Or will I have to get new springs front and rear or is there another route? Thanks, BUTTE
Old Sep 22, 2009 | 06:32 PM
1988-305-tbi's Avatar
Re: 86 IROC is too low
fix your exhaust problem, don't jack up the car, it's a camaro not a jeep, your problem is that your exhasut is to low correct???? so raise the exhaust.
Old Sep 22, 2009 | 06:36 PM
BUTTE's Avatar
I built the exhaust system myself as that is what I do. It is as close to the cross members as possible without touching. I'm not wanting to skyjack it just an inch or so to clear the nasty railroad crossings and such.
Old Sep 22, 2009 | 06:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
moog iroc replacement springs will most likely raise the car an inch at least.
Old Sep 24, 2009 | 07:13 PM
BUTTE's Avatar
How much would the replacement springs cost as compared to installing a larger set of tires or is installing taller tires an option?
Old Sep 24, 2009 | 07:17 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
69 per spring
Old Sep 24, 2009 | 09:11 PM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
I had a similar problem.
wasn't the exhaust!
wasn't the springs!
It was the engine mounts!!!!
both were old and for lack of a better term, collapsed or shorter than new ones.
I replaced them and had no more clearance issues, other than normal!
good luck,
If you change them the nuts inside the crossmember are a @!^%*$#!*.
Old Sep 25, 2009 | 03:11 PM
wasn't the exhaust!
wasn't the springs!
good luck,
NO!!!!!!!! motor mounts do not effect clearance, why the hell would you think that???????????? if the motor mounts fail than the mmotor will rest on the k member, and still no clearancew will be lost, the oil pan may drop 1/2" but it's still above the k member and way above the exhaust
Old Sep 25, 2009 | 03:16 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Go to a bigger new tire. 255/50r16 will be a good bit taller than a bald 245/50r16.
Old Sep 25, 2009 | 05:32 PM
Axle/Gears: unknown
If the engine is closer to the crossmember or K- frame, since the exhaust is connected to the engine, then it will sit lower as well.
Why in the hell would I think that?
Because, my exhaust was low and scraping speed bumps, etc.
It was hanging lower than the bottom of the car.
I replaced the motor mounts.
Both mounts were 1/2 to 3/4 of an inch shorter than the replacements.
Since the mounts are on an angle, it raised the engine more than the difference of the old to new mounts.
My exhaust did not scrape anything after that!
It raised the exhaust and engine signifcantly.
This is not an opinion, IT IS WHAT I DID to my 84 Trans Am.
This may or may not be your problem, just sharing what I did to correct a similar issue.
Old Oct 1, 2009 | 09:40 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Where'd you run the exhaust to loose clearance? Not bashing, just curious.
A 255/50 is just a slightly wider tire than a 245/50 and about .4 inches taller overall. That'd be less than a 1/4 lift...
Old Oct 1, 2009 | 01:58 PM
BUTTE's Avatar
Well it's not that it's too low for me as I have never had it drag, I ran the exhaust straight back from the headers then angled toward the center of the car on each side of the driveline back to the mufflers and dump out in front of the rear axle. I am selling the car and the guy who is buying it is about 6'4" and well over 300lbs plus his son is just as big, he was wanting to know the best way to get some more clearance I told him since the tires are worn out that I'm losing at least a 1/2 inch there and if he put a taller tire on it that should fix the issue. He's kinda overly afraid with his and his sons weight that he might tear something up if he happens to bottom out on something.
Old Oct 1, 2009 | 02:04 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I'd change the exhaust. But short of that, just get some new springs and GOOD shocks/struts in it and it should be pretty resistant to bottoming out.
My Konis kept my old dual 3inch off the ground easily. But they're a hell of a lot more expensive than the average catback.
Old Oct 1, 2009 | 02:15 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I don't think my car would clear that too well haha
Springs and shocks and maybe a taller tire would help. But, keep in mind- changing tire sizes will mess up the speedometer and odometer.
Old Oct 1, 2009 | 02:29 PM
BUTTE's Avatar
Ok thanks for all of your suggestions. I gave the guy who wants the car all of the recommendations and if they buy it they have all the proper info they need, Thanks, BUTTE
Old Oct 1, 2009 | 02:44 PM
Car: 1994 Trans Am
Right, but if his 245s are near bald like he said above, i'm not sure how tall tread is on a new tire, but that plus the .4 inches, overall it could be close to 3/4 inch taller than he is now. Does that make sense?
Old Oct 1, 2009 | 03:13 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Yes it does. But the tread depth is only 9-11/32s. That plus the .2 inches (it's .4 over all, but only half of that is on the ground at once) is still about half an inch. It'd help some, but not a whole lot. Still worth a shot though.
Old Oct 1, 2009 | 04:24 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i would get the new springs first, your stock ones are most likely shot anyway. See where it gets you, they pick a larger tire to fill the wheel well if you want to.
87iroctheo
Dec 4, 2016 11:47 AM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
g.l.mos
Aug 22, 2015 12:02 AM
Fronzizzle
Aug 17, 2015 02:52 PM
mustangman65_79
Aug 11, 2015 03:17 PM
