Question about sway bar size
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
Went to the junk yard today and found a 90 firebird that had a performance suspension (as indicated on a plaque in the interior) the front and rear sway bars are visually bigger then what is on my RS. Can anyone tell me what size they could be?
Also would it be better to upgrade my sway bars from another 3rd gen or buy aftermarket? Thanks
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Question about sway bar size
The above combo is the largest OE bars that our cars came equipped with.
JamesC
Engine: LO3
Axle/Gears: 3.08
Thanks for the reply, so in your opinion are the hollow stock sway bars equal to/better then the solid aftermarket sway bars? Or am i better off getting solid after market?
JamesC
Engine: LO3
Axle/Gears: 3.08
Roger that, i think ill nab them from the car clean them and powder coat em. Thanks!
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Sorry to bring this old thread back, but would my 90 formula have a 24 mm rear? I need to get new bushings ASAP.
Engine: LO3
Axle/Gears: 3.08
your best bet is to get a micrometer from auto zone or any other parts store and get an absolute measurement for your self. It's what i did and i found the exact sway bars I wanted. I took those swaybars (36mm 24mm) cleaned them up and got them powder coated and hadn't looked back since. Good luck!
I'd measure along the bar in several places. Of course, you could use a monkey wrench, then measure across the jaws (less exact but doable).
JamesC
JamesC
Oh okay thanks. I was thinking it was the diameter of the holes on each end of the sway bar for some reason.
Engine: LO3
Axle/Gears: 3.08
I don't think there is a dumb question, thats actually a good one. I don't know if there is a correct part of the sway bar to take measurements from however i used my micrometer and took measurements from the very center of the sway bar.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i would measure the bar in the center area, where its not bend. The bar distorts in the bends and you cant get a accurate reading.
The bar should be the same size all the way across right? I measured a couple areas near the tire and got 24 mm so went ahead and bought bushings for the 24 mm bar.
Car: 86 Trans Am
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
