bad wheel hop
Subscribe
Dec 3, 2009 | 11:04 AM
hi guys..what do i need to get rid of my wheel hop SFC?.Lower Control arms?..its an 89 formula with 255 size wide tires thanks
Reply 0
Dec 3, 2009 | 11:46 AM
Re: bad wheel hop
control arm relocation brakets
Reply 0
Dec 3, 2009 | 02:56 PM
Re: bad wheel hop
He didn't say if it was lowered or not, and it shouldn't need LCARB's if it is at stock height.
If it is at stock height, try poly LCA and TA bushings.
Reply 0
Dec 3, 2009 | 03:50 PM
Re: bad wheel hop
yeah sorry about that..its stock height..what brand Lower Control Arms do you reccomend?
Reply 0
Dec 3, 2009 | 03:57 PM
Re: bad wheel hop
Everything you didn't necessarily want to know:
https://www.thirdgen.org/forums/susp...nderstand.html
Reply 0
Dec 4, 2009 | 11:19 AM
Re: bad wheel hop
Hello
I noticed that you are having wheel hop issues! Actually it could be a few different things causing this. I would suggest looking into (like mentioned above) The lower control arm relocation brackets. And also look into replacing your stamped factory lower control arms. And it could go as far as your spring and shock combo. These are just a few suggestions and below is a link to show you what all UMI Performance has to offer!
http://www.umiperformance.com/catalo...93jivatbf8ihq7
Hope that helps!
Brad
Reply 0
Dec 4, 2009 | 01:52 PM
Re: bad wheel hop
LCARB's aren't going to help if he doesn't need them.
You can tell if you need LCARB's by looking at your LCA angle. If they are lower at the front than the rear, LCARB's should help, but if the rear of your LCA's are lower or if they are level you shouldn't need them.
Wheel hop is usually caused by worn or damaged parts, such as bushings or shocks.
Reply 0
Dec 4, 2009 | 03:18 PM
Re: bad wheel hop
Hello
What I meant by it is if the rear control arms rubber bushings are shot. Then they would allow the control arm to flex therefore causing the wheel hop.
If you have any other questions feel free to ask and I will be more than glad to help.
Brad
Reply 0
Dec 4, 2009 | 05:14 PM
Re: bad wheel hop
I don't think a bad bushing would cause the LCA to flex, it would just allow excessive flex in the bushing.
Reply 0
Dec 4, 2009 | 05:29 PM
Re: bad wheel hop
With the relocation bracket you can change your instant center on the car and increase traction and eliminate hop on a lowered or stock car. Best bang for your buck in this situation.
Reply 0
Subscribe
