weeble wobble help
Old Mar 3, 2010 | 08:13 AM
Weffy's Avatar
Car: (sold 85' IROC Z28)
Engine: (89' 305 TPI)
Transmission: Looking for a classic chevy
weeble wobble help
So, I bought an 85 IROC yesterday, and one of the many issues besides the rod knock, bad transmission, no headlights, and it overheating in my driveway is... the front driver tires has what I like to call a 'weeble wobble' to it. The whole car started shaking violently on the way home, I stuck my head out the window and the wheel looked like it was about to fall off.
http://cgi.ebay.com/ebaymotors/Camar...ht_1672wt_1110
Do you guys think this will fix that problem?
Old Mar 3, 2010 | 08:44 AM
jj74sd455's Avatar
Car: 91 bird
Engine: 305 tbi
Transmission: 4 speed automatic
Axle/Gears: factory
Re: weeble wobble help
i take it you already checked tires for flat spots or goose eggs, and wheels for bends or damage
Old Mar 3, 2010 | 08:46 AM
Weffy's Avatar
Yeah, I put different front tires on, still did it.
Old Mar 3, 2010 | 08:57 AM
jj74sd455's Avatar
Car: 91 bird
Engine: 305 tbi
Axle/Gears: factory
howd the rotors and breaks look when you had wheels off?
Old Mar 3, 2010 | 09:03 AM
Weffy's Avatar
They looked a little worn, but nothing bad. I mean, this wheel really looked like it had 1 lug on it or something, I don't think anything like warped rotors may have caused it.
Old Mar 3, 2010 | 09:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Wheel bearing?
JamesC
Old Mar 3, 2010 | 09:09 AM
Weffy's Avatar
hmm I don't know much, how would I go about checking the wheel baring besides switching the 2 sides?
exarkun1178's Avatar
ive had that twice. once, 3 of the 5 studs had broken off with the other 2 lug nuts almost all un fastened. lucky i had noticed when i did(saw a part of car come flying off as i was looking through side rear mirror{was one of the studs}) this i would expect not the issue as you would notice missing studs. maybe nuts not torqued down?
the second time i had very low air in tire.
maybe a bent wheel?
Old Mar 3, 2010 | 09:14 AM
Weffy's Avatar
Ok, I'm going to double check all the studs now.
Old Mar 3, 2010 | 09:18 AM
jj74sd455's Avatar
Car: 91 bird
Engine: 305 tbi
Axle/Gears: factory
id jack up the car and check the play in the wheel, id wanna locate the problem before throwing money at it
Old Mar 3, 2010 | 09:21 AM
JamesC's Avatar
Since you put new tires on it, I'd have thought you'd have noticed if studs/lugs were missing. Did you swap from side to side to verify that a wheel isn't bent?
JamesC
Old Mar 3, 2010 | 09:23 AM
Weffy's Avatar
No, the car came with polished aluminum rims on it and the original wheels that I put on the front. I did it just when I woke up, so I don't really remember anything. How much play in the wheel should there be? Is that like how loose it is?
Old Mar 3, 2010 | 09:27 AM
jj74sd455's Avatar
Car: 91 bird
Engine: 305 tbi
Axle/Gears: factory
if you jack it up and grab the wheel with both hands and wiggle there should be no play back and forth,if so more than likely wheel bearing
Old Mar 3, 2010 | 10:06 AM
Weffy's Avatar
Ok, put the car up and the wheels has a lot a play in it. I don't know how I didn't notice that when I changed the wheels.
It's not the wheel bearing I suspect though, It has something to do with the steering as both wheels have play and they move together. The center link looks to be wiggling where its connected to the ?idler arm?. I think thats what it is.
From the furthest point I can push it in to the furthest I can pivot it out there is about 5"
Old Mar 3, 2010 | 10:38 AM
Weffy's Avatar
Does anyone know what to replace? just the idler arm, or should I do everything while I'm at it?
And I lied, maybe 3"
Old Mar 3, 2010 | 11:40 AM
JamesC's Avatar
If the front components are original to a 25-year-old car, they no doubt need to be replaced and the steering box adjusted. That said, as JJ74 suggests, before throwing money and/or parts at the car, you'd be better served by a thorough look-see. I doubt the wheel wobble you mention is caused by a steering component.
JamesC
Old Mar 3, 2010 | 11:48 AM
Weffy's Avatar
Every steering component is loose, like, really loose. I'm going to have to replace it either way and now adjust the steering box too. The engine and transmission are getting pulled this weekend and the fun will begin. I think I'll have better access to everything with an empty engine bay.
So you're saying even though the steering components are very worn there could be something else that is contributing/causing my death wobble?
Old Mar 3, 2010 | 12:00 PM
JamesC's Avatar
Generally, I'd say that worn steering components create a dead spot in the steering, which causes the car to wander a bit. The wheel wobble seems more like a bearing problem from what you've said. The manual recommends cleaning and repacking those every 30K. Who knows if and when that's ever happened on your car? A bearing breakdown could destroy a spindle. I'd investigate more fully. A search here might also provide some ideas.
JamesC
Old Mar 3, 2010 | 12:12 PM
Weffy's Avatar
Maybe the bad bearings caused the wear on the steering? I'll just add bearings to the to-do list also haha.
Old Mar 3, 2010 | 08:50 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Take you wheel off and behind it there is a large castle nut and a cotter key going thru it. remove the cotter key and see if you can tighten it down slightly. Not to tight so it binds but enough to remove 99% of the wobble. If that doesn't fix it then while the car is jacked up and tire is on grab the tire and push on it left to right, and then top to bottom and see which has the most wobble. If there is a lot of top bottom play its ball joint if its left right its tie rod. If its both well you get the picture.
My car had some wobble to it and all i did is tighten that nut and it went away.
roysatikas
Sep 22, 2015 08:15 PM
FormulasOnly
Sep 6, 2015 10:42 AM
THETANK
Sep 26, 2002 09:28 PM
Twilightoptics
Mar 2, 2002 12:48 PM
junkyarddog
Nov 26, 2000 08:37 AM
