Brake line or Caliper?
Old Nov 21, 2000 | 02:20 PM
KS91Z28's Avatar
When I hit the brakes, the car pulls towards the driver's side, so I decided to check out the front brakes. The driver's side is showing normal, even wear. The passenger's side is showing almost no wear whatsoever. This tells me that the passenger's side caliper isn't being applied. Could the passenger's side brake line be the cause? Any ideas?
Old Nov 21, 2000 | 03:46 PM
355 IROC-Z's Avatar
it is the rf brake hose
87 iroc-z 355 TPI 5 spd. 51006 SLP cam adv. 4* (106.5* centerline)
hypertech stage II chip/ 160* stat./ Airfoil, accel AFPR
19# injectors, ported plenum and runners. 9.8:1 compression
stock heads, pocket ported, 1.94 int., unshrouded.
stock exhaust manifolds and y pipe! hopefully soon to change
3.45 rear (stock)
Flowmaster, K&N w/ hacked airbox/removed MAF screens
14.38@100mph 2.2 60'
Old Nov 21, 2000 | 04:13 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
I also had the same problem. I changed both front brake hoses and the pull was gone. Remember that there are left & right brake hoses.
-Auggie-
Old Nov 21, 2000 | 05:25 PM
KS91Z28's Avatar
Thanks guys! That pretty much confirms what I was thinking.
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
