Steering column question (New here and to third gens)
Old Apr 11, 2010 | 11:09 AM
cochran88's Avatar
Car: 1989 Firebird Formula WS6
Engine: 5.0L HO
I have an 89 Firbird Formula that I just bought not to long ago. It wasnt running whne I bought it and now its all running and what not. So my next big issue is the steering column moves a good inch or two in any direction at anytime... Im not talking about just the steering wheel the whole column just to make that clear. Is it time to head to the junkyard and get a new column or is there a rebuild kit or something else I need to look at?
Old Apr 11, 2010 | 11:21 AM
Stephen's Avatar
Car: 87 GTA
Re: Steering column question (New here and to third gens)
https://www.thirdgen.org/forums/susp...ng-column.html
Post #3 (my post) will give you a link to the fix & what I did.
The link makes it sound easy. It isn't & requires specialized tools.
Old Apr 11, 2010 | 11:29 AM
cochran88's Avatar
Engine: 5.0L HO
Well looks like I found my project for sunday afternoon! Thanks
Old Apr 11, 2010 | 11:42 AM
Stephen's Avatar
Car: 87 GTA
If you don't have the specialized tools, don't bother.
Here are pics of the inside of a later model one, so what he's doing is different, but the pics still give you a decent idea of what's going on in there.
https://www.thirdgen.org/forums/inte...eel-grant.html
Old Apr 11, 2010 | 04:31 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Maybe you just need to tighten the bolt on the shaft? Mine was loose and i had a good inch or two of slack... Tightened it and poof fixed.
Old Apr 12, 2010 | 10:07 PM
cochran88's Avatar
Engine: 5.0L HO
Yeah Im thinking its the whole column. The tilt part of the column is tight but if you pop the hood and have someone move the column around the whole shaft is moving. Havent looked into a fix yet but if someone can point me in the right direction thatd be awesome!
Old Apr 12, 2010 | 10:12 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
There is a bearing and a cover that keeps the shaft still, if the cover comes off or slips down and the bearing slips down then the column will have some play and you will see the shaft move.
At the firewall where the column comes out, there should be a cover with a round metal clip holding the cover to the large part of the shaft.
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
evilstuie
Feb 28, 2016 03:33 PM
Bull86
Aug 10, 2015 05:43 PM
