question on eibach & hotchkis springs
Old Nov 26, 2000 | 09:10 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
several people installed eibach pro-kit say their car looks the same, others say it lowers the car about 1" and some says it will settle over time. is that expected after installtion?
Old Nov 26, 2000 | 10:06 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Yes,the springs will settle over time.
Old Nov 28, 2000 | 02:40 PM
dnovotny's Avatar
I had Hotchkis springs installed. Initially, about a 1" drop. But, they sank another 5.-.75". At this drop, I have front suspension hitting the K-member, so I'm going with different springs.
Dave '91 T/A
Old Nov 28, 2000 | 06:43 PM
Jack's Avatar
So dnovotny, dont leave us in suspense! What brand are you going to replace the Hotchkis with? I was going to go with Hotchkis myself but sounds like I should consider another brand.
90 Trans Am GTA
5.0 TPI
5 Speed
T-Tops
Old Nov 29, 2000 | 03:06 PM
dnovotny's Avatar
I'm putting in Global West springs. I've been waiting 2 weeks for them to be delivered! I'll let you know the results when they're in. These springs aren't progressive, so they'll be hell of stiff, 640 lb/in front, 460 rear.
Dave '91 T/A
Mods: KB SFCs and lower chassis brace, GW rear control arms, panhard bar, and wonder bar, Spohn torque arm, Hotchkis springs and STB, Bilstein shocks and struts, PST sway bar and endlink bushings
Old Nov 29, 2000 | 03:12 PM
dnovotny's Avatar
I forgot: drop! Supposed to be less than 1 inch in front, zero drop in the rear. The guys at GW are very knowledgeable, and claim you should never exceed 1" drop in front, or you'll run into problems like I have.
Dave '91 T/A
Old Nov 30, 2000 | 02:06 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
My Hotchkis springs settled about 1/4" after i installed them a year ago. I like them, not too low, but give a good, hi-po look.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Nov 30, 2000 | 06:32 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I'm using the Eibach Sportlines and I've never encountered any problems like this with my Formula. The drop is 2" up front and 1.5" out back.
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,no cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit,MacEwen White face gauges,84 T/A cold air induction air cleaner.
Old Nov 30, 2000 | 07:27 PM
Lostsol's Avatar
I've got the Global West springs in my car and am very pleased with them. The fronts are stiff, but that's what handles the majority of the overall handleing, the rear's aren't too bad. This is still with my sensa track shocks and struts though. Also, the front did lower about an inch, on the rear I had to put in new spring isolators on top of the springs, and that seems to be common in the rear.
Old Dec 1, 2000 | 08:36 AM
dnovotny's Avatar
This type of discussion happens a lot. 10 people do a mod, and one or two have problems with it. That doesn't mean they installed it incorrectly, or something else is wrong. My SFCs also didn't fit very well, so I must've bent my frame by hand. When it comes to installing springs, there isn't much you can do to affect ride height once they're in. I didn't put a 1000lb weight in front to make it drop more. All I'm trying to let people know is, just because "MOST" don't have a problem, doesn't mean you won't.
Dave '91 T/A
sweet_87_iroc
Sep 25, 2015 10:01 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
