How hard to change LCA bushings?
I got a set of poly ones..how difficult is it..and do you have any tips?
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
JSP Motorsports
ICON Motorsports
i do it with an air chisel, and then press the new ones in. not too hard at all.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
don't think i'd want to try it. ask around at local shops and see what they'd charge to change them. shouldn't be much.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
I did mine by drilling and pounding and drilling and pounding and drilling and pounding and ... Well, you get the idea. Took forever and was a pain in the @ss. Take it somewhere and have them press them out and then back in.
Steve
Steve
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I torched the rubber till it melted,then hammered out the shells. Pressed the new ones in, Autozone rents the press for free. The rears I just soaked them with PB blaster and hammered them out and the new ones in.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
A day or so before you get ready to install them stick them in the freezer and they will shrink. It makes putting them in a whole lot easier.
as far as freezing them goes i've heard rumers of people using freon to shrink them. i'm sure it'd work but i wouldn't want to endanger the envioment just to make installing bushing easier on myself. near as i can tell all you'd have to do is hook up the gauges to the freon can and open the valve. watch out that you wouldn't get any in your eyes. like i said i've heard rumers, not sure any one would actually do this.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
All I used was a hammer and a block of wood. Insert the block in the middle of the LCA to support the walls before hammering. Just be carefull not to bend the control arm when you are hammering the old ones out and new ones in. Also I think for the front bushing you need to drill the rubber out before you use the hammer, its been awhile since i did this but I thought it was pritty easy to do.
89 GTA 350 5-speed
(Jet hot coated) SLP headers,flowmaster force 2,no cat's,SLP cold air,MSD 6al,jet chip stage 2,march pulleys,ported plenum,air foil,B&M ripper shifter,180 stat,alston SFC,spohn LCA relocation brackets,MAT relocation kit,free mods.
G-Tech times
0-60 5.3s
E.T. 13.91@104.8MPH (2300ft)
89 GTA 350 5-speed
G-Tech times
0-60 5.3s
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Ede, I'm told a little nitrogen or even carbon dioxide works just as well and is much friendlier.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
NBrehm
Aug 5, 2015 07:57 PM
