BMR vs SPOHN (sway bars)
Car: Blue 84 z28/Cyber 2010ss/rs
Engine: Dart headed, 12:1 355- 510/530 cam
Transmission: TKO 600 Lakewood Bell
Axle/Gears: Richmond 410 Spooled
SPOHN #sku923 $329
front 1 5/16 rear 1"
both solid
BMR #sbp002 $359
front 1 1/4 rear 1"
both solid
they both claim the same thing by being the best and strongest but for those of u that have em WHAT do u think???
im going to order this week to get them for next weekend
imput pls
both solid
BMR #sbp002 $359
front 1 1/4 rear 1"
both solid
imput pls
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: BMR vs SPOHN (sway bars)
depends on what you're doing with the car. if its a drag setup, either...the rear bar is the same and you don't really need the front bar for going straight.
if its a cruiser, it won't matter.
if you want it to handle, the bigger front bar from spohn will make it "tighter" or tend toward understeer.
save some money and get used stock bars...there's several different sizes and they are all a lot cheaper than going with one of the aftermarket companies.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
depending on what you have dont to the car and what you plan to do with it, the rear bar may be too much. The front bar is going to be really heavy.
maybe consider picking up a factory 36mm hollow front bar? quite stiff, usually enough for just about anything you do with the car, a lot lighter than a solid bar, and a fraction of the price!
a 1" solid rear bar is a stock size, you can pick that up used for cheap too.
i live in a small town with lots of back roads and twistys,
are u saying that the stock front is stiffer then what im looking at
the car only has a spohn tranny x member with adjustable t/a adjustable p.h.r , trailing arms and eibach pro kit, also have a strut tower brace
need a wonder bar and drop brackets for the trailing arms
Car: 86 Trans Am
Car: 86 Trans Am
People use the Spohn bars, im sure they are good parts, i just saying that you can do pretty well with a 36mm bar, and they are a lot cheaper. Have a 36mm and a 19mm on my 86 and it handles pretty darn well. the 24mm/1" solid hotchkis bar i had was way to stiff for the rear.
Im lookinf for another 36mm bar for my 92, and have my eye on the adjustable hollow 15/16 rear bar that hotchkis has.
thanks for all the imput
darwinprice
17
Oct 11, 2015 11:51 PM
