Car pulls when braking
Old Jan 26, 2001 | 04:01 PM
JoeIROC's Avatar
My car pulls very hard to the right when i brake at higher speeds ( >50 mph). When I am going very slow (10 mph) i dont notice the pull. Basically, the slower I apply the brakes, the less that the pulling occurs. So when i jam on the brakes the car pulls really hard, but when i go nice & easy on it, there's no pull.
I replaced the front pads and bushings, lubed all the sliding parts... with no improvement.
I was wondering what you guys might think could cause this. I was thinking it's the front brake hoses. I really have no other ideas.
Any help would be truly appreciated.
Joe
Old Jan 26, 2001 | 05:00 PM
irocluke's Avatar
i had the same problem last year. i replaced both hoses and it was as good as new.
www.irocluke.freeservers.com
Old Jan 26, 2001 | 05:03 PM
JJ's Avatar
JJ
ditto on the brake lines
Old Jan 27, 2001 | 12:47 PM
88IROCARMY's Avatar
The rubber hoses(especially right side) collapse. I found that new hoses help. But the brained steel are the preventive measure.
Old Jan 27, 2001 | 05:10 PM
JoeIROC's Avatar
Yes, I replaced both hoses...
It worked!
As a side note, i bled the brakes before I removed the old hoses. FYI, the bad line bleeds MUCH slower than the good line. That tells you you have a restriction of some sort.
Your help is truly appreciated, thanks again gents.
Joe
86 IROC TPI
700-R4
K&N Air filters
Old Jan 27, 2001 | 07:55 PM
FBODY-ADDICT's Avatar
When you replace your hoses check your brake shoes, usually when something like this happens it means one side is taking twice the beating that the other side is.
Even if only one side needs replacement change both sides regardless.
Old Jan 28, 2001 | 01:22 AM
transampwr's Avatar
Car: 2003 SVT Mustang Cobra
Engine: 4.6L DOHC Supercharged
Axle/Gears: 3.55
Y'know, the answer could be as simle as checking the tires and making sure that the psi is even. Cuse if the psi isn't even then one tire has more grip than the other.
It's all fun and games 'till someone looses an eye....then it's fun yu can't see!!
1987 Pontiac Trans Am
-305 cid motor (soon to be gone)
-Flowmaster Muffler
-Yokohama Tires
-3" Exhaust Tips
-180 degree Thermostat
-JVC Head Unit w/ Kicker subs!
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
