"OFFICIAL" Lowered 3rd Gen Picture Thread (Post Your Pics Here)
Old Oct 22, 2010 | 06:00 PM
  #201
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: "OFFICIAL" Lowered 3rd Gen Picture Thread (Post Your Pics Here)
If you cut them, you'll raise spring rates (making it stiffer) which is what i've read a good thing with these springs as they tend to be a bit soft for a high performance handling car.
Old Oct 22, 2010 | 07:51 PM
  #202
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Originally Posted by RubberDucky
Lol, is that tubbed? That's what I want to do to my Camaro, is it streetable at all like that?
The car is very streetable, drive it every weekend
Old Oct 23, 2010 | 12:16 AM
  #203
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
so had someone put 4 new springs on and two rear shocks. is it posible they switched something cause my front is to low and my rear is to high. here is the best pic for now. they put the thiner longer spring in the rear and the short fat one in the front. is this correct? will new struts raise my front any? cant drive it its so low. less then a half inch from fender. if someone can help me out ill post better pics. they are drop zone 1.75 front and rear. but if anything it raised my rear and extremly lowered my front.
camarolowered.jpg?t=1287810899
Old Oct 23, 2010 | 12:26 AM
  #204
Stephen's Avatar
Car: 87 GTA
Well....It is IMPOSSIBLE to interchange the fronts & rear springs.
For the rear......If you put in dropped springs, the old stock springs coulda been so worn out, they were sagging so bad, that the dropped springs are actually raised the car. Lower than stock, but higher than it was.
What is your ride height at the fender lips to the ground? Here's mine & it is a daily driver.
Old Oct 23, 2010 | 12:39 AM
  #205
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
Thought so... just didn't know if somehow someway they figured it out. Not sure the fender height will get that tomorrow. I'm running 17 by 9.5 with 275's and a 2.5 inch spacer.
Old Oct 23, 2010 | 02:13 PM
  #206
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Old Oct 23, 2010 | 10:27 PM
  #207
carkook's Avatar
Old Oct 24, 2010 | 11:17 PM
  #208
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
24 3/4" from ground. will front struts help any. any way to move or i guess remove the inner fender. also does anyone know if qa1's front coil over struts will work with my stock setup. plan on doing a k member swap but dont have all the cash right now and i need new struts will they work?
Old Oct 25, 2010 | 12:36 AM
  #209
Stephen's Avatar
Car: 87 GTA
Did you buy lowering springs for a V6 car & put them on a V8 car? If they are V8 springs, were a few coils lopped off? Those are the only ways I can think of that your car is that low. You sure the fronts are even IN the car? Is there ANY suspension compression there? Struts only control up & down motion speed, they don't support any weight, so new struts won't help you any.
I would look into why your front end is that low. Something is definitely not right.
Old Oct 25, 2010 | 12:48 AM
  #210
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
They are brand new dropzone springs. There suppose to be for a v8. Just contacted the company I got them from hoping something will come of it. They are for sure in it with no coils cut off. So well see...
Old Oct 26, 2010 | 04:18 AM
  #211
maule6's Avatar
Car: 92 RS Camaro T-Top
Engine: 305 V8
Transmission: 5 speed manual
Axle/Gears: stock
Originally Posted by sailtexas186548
here's a recent one, dropzone front springs, cut stock rear springs, need to cut more but i'm waiting until my taller tires are on before i cut
too much
what brand manufacture is the hood from??
Old Oct 27, 2010 | 10:52 AM
  #212
Skyset's Avatar
Car: 86 Iroc-Z
Engine: 305 (TPI)
Axle/Gears: i dunno lolz
Lowered my car on DropZone springs yesterday!
Old Oct 27, 2010 | 11:38 AM
  #213
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
Looks good didn't slam the front like mine. But the rear still looks high. Mine is worse than before.
Old Oct 27, 2010 | 11:46 AM
  #214
How much do dropzone springs lower the car? And did you keep the spring isolators in there? Also, any weight reduction in the front end? It looks quite low to me in the front! How high is the ground height to the fender height (in the middle of the fender)
Old Oct 27, 2010 | 11:51 AM
  #215
Skyset's Avatar
Car: 86 Iroc-Z
Engine: 305 (TPI)
I don't understand why the rear isn't as low as the front of my car...DropZones advertise 1.75" drop on both front and back...
The mechanic who put them in said it's going to take a week to "settle". Does anyone know if that's true? I'm happy with it's stance, just curious as to why the back is a little higher then I was expecting it.
Old Oct 27, 2010 | 12:17 PM
  #216
Ahhh.. Yeah it does take a bit of time to settle.. Took me a bit more but i put on stock MOOG iroc springs (very stiff) and the car was JACKED up for about 2 weeks! I also put in 4th gen spring isolators by accident so it's quite a bit higher than stock was.. But I'm putting on 2" Racecraft drop spindles and Koni yellows (relocating battery to rear and will cut rear springs to match the front after all weight has been re-located) so it should look real nice and low and handle even better when all that is done.
Old Oct 27, 2010 | 12:25 PM
  #217
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
Let me know what you find out mine is same way.
Old Oct 27, 2010 | 01:24 PM
  #218
zz17iroc's Avatar
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
Here's mine nothing special just some cut springs.
Attached Thumbnails "OFFICIAL" Lowered 3rd Gen Picture Thread (Post Your Pics Here)-wet-1.jpg   "OFFICIAL" Lowered 3rd Gen Picture Thread (Post Your Pics Here)-wet-2.jpg
Old Oct 27, 2010 | 01:31 PM
  #219
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
i have no idea, i bought it used. sorry i cant be more help
Old Oct 27, 2010 | 01:43 PM
  #220
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Drop zones are 1.75 lower. The back of my car sat high also. I just took out the isolators and put heater hose over the first coil.I probably got another 1/2 drop in the back by just taking out the isolators.
Old Oct 28, 2010 | 01:23 AM
  #221
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
Can you hook me up with the link to the spindles can't seem to find any
Old Oct 28, 2010 | 10:40 AM
  #222
http://www.racecraft.com/index.php?m...products_id=70
That is for their 2" drop spindles. They weigh slightly less than stock (8.4lbs total less weight) and that is unsprung weight on the front of the car which is good. They work with stock steering style system (steering box, NOT R&P) and stock or aftermarket brakes.
Old Oct 28, 2010 | 10:54 AM
  #223
dust3r's Avatar
Car: 1986 z28 & 1992 z28
Transmission: 700-R4
How wide are your z06 wheels? If they are the 9.5" version, they won't work with the drop spindles (unless you want to run MASSIVE wheel adapters which will push your wheels out past the fenders) because they will hit your outer tie rods.
Old Oct 28, 2010 | 11:40 AM
  #224
I thought wheel spacers are dangerous? Especially when racing..?
Old Oct 28, 2010 | 02:06 PM
  #225
SRT88GTA's Avatar
Car: 1988 GTA
Transmission: 700RH4
Is this there one one inch lowering set? The height is just what I am looking for.
Old Oct 28, 2010 | 10:51 PM
  #226
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
they are 9.5's but im already running 2.5 inch spacers in front. will they still work?
Old Nov 2, 2010 | 12:44 AM
  #227
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
here is a better pic. i love the way it looks but its TO low. i would suggest to anyone thats considering buying dropzone springs to remember you get what you paid for. i have already bought some sportlines and kyb struts to go with my qa1 rear shocks. i will post a pic when thats done.
camarolowered1.jpg?t=1288676538
Old Nov 2, 2010 | 05:33 PM
  #228
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
i was thinking about getting dropzone springs, whats wrong with them? why is it TO low? air dam?
Old Nov 2, 2010 | 05:36 PM
  #229
Twin_Turbo's Avatar
Looks just right to me, so what if it scrapes. *drop zones on to buy list*
Old Nov 2, 2010 | 05:51 PM
  #230
itsMikey's Avatar
Engine: 5.7 350 TPI
thats what im sayin..lol..
i want a good drop and ride..
doesent bug me tho, bumps arent TOO bad around cali..driveways is what gets me
Old Nov 2, 2010 | 06:37 PM
  #231
84 z28's Avatar
Car: 1984 z28
Engine: 355
I have the drop zones on my car. The ride nice and they lowered the car to a perfect stance. I bought mine off of ebay. You cant beat the price. $113 for all 4 shipped to your door.
http://cgi.ebay.com/ebaymotors/NEW-D...Q5fAccessories
Old Nov 2, 2010 | 07:11 PM
  #232
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
Every little bump I hit it shoves my inner fender up and rubs my tires. They claim that v6 and v8 springs are the same. I got mine off eBay to. And my rear is about 4 inches off rear tires.
Old Nov 2, 2010 | 07:51 PM
  #233
84 z28's Avatar
Car: 1984 z28
Engine: 355
Dosent help that you have the wide wheels and a 2" spacer. If your rims were closer to stock width or you just didnt have the spacer you probably wouldnt be rubbing in the front.
Old Nov 2, 2010 | 09:38 PM
  #234
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
Ah that's the kicker. I installed stock wheels and tires and same thing to high in rear to low in front
Old Nov 5, 2010 | 07:21 PM
  #235
Skyset's Avatar
Car: 86 Iroc-Z
Engine: 305 (TPI)
I strongly recommend against anyone using dropzones. I highly regret putting mine in. Look a few posts above to see pics of my car. The front air dam was literally only 1 inch from the ground. It was hitting the ground on every little crack on the road...it fell off last week on the way to work -.-
I'm in the process of ordering some Eibachs and a new air dam.
Old Nov 5, 2010 | 07:24 PM
  #236
itsMikey's Avatar
Engine: 5.7 350 TPI
hmm...ill just trim the air dam then?
Old Nov 5, 2010 | 07:36 PM
  #237
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
I strongly recommend anyone using dropzones. I highly regret putting mine in. Look a few posts above to see pics of my car. The front air dam was literally only 1 inch from the ground. It was hitting the ground on every little crack on the road...it fell off last week on the way to work -.-
I did the same. And gsx struts. Take off air dam. I put 160 thermastat and a fan switch it stays cool.
Old Nov 5, 2010 | 08:59 PM
  #238
ditchbangr's Avatar
Car: One of 5
Engine: LB9
My 91z with eibach pro kit and tokico shocks.
Old Nov 5, 2010 | 09:34 PM
  #239
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
Eibach sportlines are the way to go. Takes about 1000 miles to settle tho.
Old Nov 5, 2010 | 09:48 PM
  #240
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I had Eibach Pro-Kit on my '93 Beretta GTZ... The ride was nice but I didn't think it was low enough; then I put the Sportlines on my '04 SRT-4 and I barely made it 1000 miles before I put the stock springs back on - The Sportlines rode like total junk - CLEARLY the Pro-Kit is the way to go, they are for performance whereas I think the Sportlines are purely for a look (a look that apparently means bouncing down the road and scraping everything in sight).
Old Nov 5, 2010 | 10:52 PM
  #241
Stephen's Avatar
Car: 87 GTA
Eibach springs yes. Sportlines no.
Get a set of Ground Control Weight Jacks with Eibach springs!
Old Nov 5, 2010 | 11:00 PM
  #242
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
Crap so sportlines are a no? That's what I.just bought. Getting ready to.have installed...
Old Nov 5, 2010 | 11:21 PM
  #243
theNMBR27's Avatar
Hey those were given to me for free and so what if they ride hard I'm not driving a Cadillac. To each his own.
Old Nov 6, 2010 | 01:47 AM
  #244
A.F.U.'s Avatar
Car: '91 Z28
Axle/Gears: 3.23/posi
Eibach springs were already installed on my Zwhen i bought it in '05,i'm not sure which ones they are though,the sportline or prokit.Can someone tell me just by lookin' at this pic?
Old Nov 6, 2010 | 03:44 AM
  #245
Manovox's Avatar
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
Here is mine! not only the springs but from when I blackened the headlight pockets it look mor low for me! what you think?
Old Nov 6, 2010 | 06:52 PM
  #246
theNMBR27's Avatar
AFU jack the car up and look at the springs. It should be written on them.
Old Nov 6, 2010 | 06:56 PM
  #247
Manovox's Avatar
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
sportline are red and prokit are black
Old Nov 10, 2010 | 05:31 PM
  #248
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
here is the finished product thus far. kyb agx adjustable struts and qa1 rear adjustable shocks. and sportline springs all the way around. not settled yet so ill post pics when it does.
before: with dropzones = crap, looks good but un-drivable
camarolowered1.jpg?t=1289431763
after: with sportlines
camarolowered2.jpg?t=1289431545
camarolowered1-1.jpg?t=1289431620
camarolowered3.jpg?t=1289431660
camarolowered-1.jpg?t=1289431843
Old Nov 12, 2010 | 03:38 PM
  #249
A.F.U.'s Avatar
Car: '91 Z28
They are pro kit,thanks for the advice!I didn't think it would be as simple as it being written on the spring itself.
Old Nov 12, 2010 | 03:56 PM
  #250
It would be great to see the distance between the center fender lip and the ground (height), that way we can compare you guys' measurements to our cars because I find it difficult to judge the height by eye from pics.
