"OFFICIAL" Lowered 3rd Gen Picture Thread (Post Your Pics Here)
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: "OFFICIAL" Lowered 3rd Gen Picture Thread (Post Your Pics Here)
love the colour combo on your!! ^^ love those wheels
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
heres mine on Eibach Ground Control
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
Damn that's a perfect stance! Untill the speed bumps of course
Engine: 5.7 350 TPI
yeaa loving that stance..i need to drop my rear a tad more..my front maybe just a LITTLE more too..need to do something about the inside of my fenders tho
want spacers for the rears too..
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
What is everyone doing with their bump stops? I'm running stock right now, but almost touching front at rear just as the car sits. Can always cut em in half but dont want to risk damaging something else. Curious if there is a better after market alternative
Hey guys.. ive been out of the F-body scene for about 5 years (5 years too long). I just got my 88 IROC last tuesday, its a beauty.. only 70k miles and completely original.. garage kept and never driven in rain or snow.. had to drive 5 hours to pick it up, but it was worth it. I didnt even have it 24 hours before ordering the first round of parts (among thoes parts were moog inner and outer tie rods, centerlink, idler arm, solid tie rod adjuster sleeves, new shocks and struts, a new exhaust... and of course Eibach pro-kit springs and an adjustable panhard bar)... this is before, hopefully i will have some after picks tomorrow evening, only got the exhaust done before it was time to close up the shop.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Engine: 5.7 350 TPI
Car: 84 Z28 Camaro
Engine: 305 H.O.
Transmission: TH 700R4
Axle/Gears: GM 7.625 w/ 3.42 ratio
Hate to be a pest, but does anyone have any pics of a 82-84 Z28 lowered? Would love to see that.
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Awesome! Thanks! They apparently lower the front 1.6 inches and the rear 1.3 but yours looks very equal front to rear.. To be honest I had drop spindles in the plans for spring 2012 and wanted to know where your car was at for comparison, as I would probably get lowering springs only in the rear or cut my MOOG 5665 springs (reduces weight and increasing spring stiffness as well as a bonus).
Car: 1985 Camaro Z28
Engine: 355
Axle/Gears: 7.5 with 4.11 gears
Here is my car with cheap k sport springs from ebay
I'm still not home. When I am, I'll measure and reply......
Ok I have the measurements you asked for.
Front: 24.5"
Rear: 25.5"
I have 17" torq thrust II wheels with low profile tires.
Hope this is helpful man.
Front: 24.5"
Rear: 25.5"
WOW that is really low!! It looks good though.. right now my fronts are around 27.5, maybe a bit higher now cuz of minor weight reduction, but I think dropping my car 2" at the spindles will make it handle and look alot better.. The rears will definitely need to be cut a coil or two to match the front drop.. Right now my rears sit around 28".. And have new front and rear isolators (the rears are a bit thicker than stock cuz they are the 4th gen ones..)
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
after lowered with eibock sportlines. and below is before with stock
Car: 1992 Camaro
Transmission: t-5
How do drop spindles work? Wanting to drop it a little more but I have to keep the tires out of the fender.
the only ones for our cars right now are the Racecraft drop spindles, and they are only available in 2" drop. You can get them for OEM or aftermarket brakes, as well as have them modified to fit tubular a-arms (they were willing to do this custom for me for 50$ extra). You can also get the rack & pinion version.
It moves the mount for the hub up 2" on the spindle, so it drops everything and keeps the stock front suspension geometry. They are also a tad lighter (4.2lbs per side for a total of 8.4lbs of unsprung weight). This lowers the CG quite a bit so it definitely improves handling but unfortunately with lowering comes a slew of other issues, such as rear LCA's being at the wrong angle, PHB might need to be adjusted and/or lowered at the axle mount, pinion angle might be affected, etc. If you already have adjustable suspension pieces like I do, then it's just a matter of adjusting everything once the car is dropped.
They are a bit expensive and that's why I want to be sure that I'll be happy with the height that I'll be at.. It's already tight under the car so I might raise the car slightly with spring spacers or something after I drop it with these spindles.. That might be delayed because I'm also planning on dropping in a 383 with alum. heads which will be about 50lbs lighter than my iron block/heads that I have now.. That might raise the front end slightly, like a half inch or so.
Yeah but I think I will raise the front to match the rear. O'reilly has a variety of spring boosters I hear. I'll go for the best quality ones. I hope they work!
[quote=cIaRmOaCrZo;5089571]
Looks MUCH nicer now man. You should think of getting a pair of these for your car:
http://www.ebay.com/itm/1982-92-CAMA...item4cf97a7437
I found mine somewhere else for cheap but I can't remember where.
Car: camaro 1984
Engine: 305 willing to go to lsx
Transmission: 700 i gues?
Axle/Gears: stock and i dont realy know
here is my camaro 1984 2" lowered on back and 1 3/4 front.
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Car: camaro 1984
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I cut 1/3 of a coil off my fronts, and 1/3 off my rears and removed the isolator and my car still sits high. It's always sat high it seems...
I need more drop, but Im not willing to cut more off the springs, I need the rates balanced...
And how it sat before:
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Something to remember for people complaining that the rear sits too high. When you sit inside the car, your rear end will drop down aprox 0.5 to 0.75 inches. Have somebody measure it with you in the car. Or simply have somebody the same body weight as yourself sit in the driver's seat and see if you like the way the back end looks.
I'm 230 lbs and have uncut 5665 springs in the back. And I get 0.75" drop.
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
^ ore picsss
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
dont know if this was covered at all yet, and i honestly didnt feel like looking cause my computer is putting up a fight. anyways v6 vs. v8 springs, are they the same stiffness
Engine: LSX
Transmission: MN12
Car: 1986 Trans am
Engine: 5.3 LM7
Pretty sure the answer is no. Ride height shouldn't change much between a V8 and V6 spring, but they are not as stiff as V8 springs. My brother left the stock V6 springs in when he did a 350 swap and ride height wasn't affected really.....seemed like the car drove decent honestly, but not as firm as my factory WS6 setup did.
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
im just debating to cut a pair of v6 or v8 ones for now. down the road i will invest in a set of lowering springs but i have to get my car on the ground and moveable, and i dont feel like having to take them out right after i put it back on the ground. sorta like its at the height id like it and ill correct it later on if that makes sense
Its metallic silver.
