What to coat subframes with?
Old Feb 12, 2001 | 12:52 PM
Boham92RS's Avatar
I had SSM subframes installed in my RS last year, and I did not coat them with anything before installing them. Needless to say, they are now rusting a bit, but not terribly bad. (Car is always garaged)
What should I use to coat them? Ive heard good things about POR15, but shoudl I just use an undercoating type spray?
Old Feb 12, 2001 | 03:57 PM
Jza's Avatar
Jza
I sprayed mine with primer and rustoleum, but I don't think it's durable enough to take what goes on down there.
Old Feb 12, 2001 | 04:43 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
if you only bolted them in the take em off and have the sanded and powder coated
thatll do it
1983 CHEVROLET CAMARO with a 1986
305 C.I.D.V8 BORED .030 OVER
HIGH VOLUME OIL PUMP
FLAT-TOP PISTONS
MILD CAM
3" CAT BACK EXHAUST W/ FLOWMASTER MUFFFLER
KEYSTONE CLASSIC WHEELS.
B&M RATCHET SHIFTER
STAGE THREE SHIFT KIT
(she'll spin em into third)
MUSTANGS SUCK
Old Feb 12, 2001 | 06:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
POR15, just don't get it on your skin and make sure you use it in a well ventilated area.
Old Feb 12, 2001 | 09:16 PM
Nightcruzer's Avatar
Car: Trans Am
I second the por15, when properly prepped and applied you can hit it with a hammer and it won't chip. www.por15.com
[This message has been edited by Nightcruzer (edited February 12, 2001).]
Old Feb 13, 2001 | 09:26 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I third the por-15. Use all three of their steps (marine-clean, metal-ready, por-15) for the best coating. I used their "super starter kit, semi-gloss black" to coat my rear axle. It was a great deal at $15 + $5 for shipping; and it was just enough for the job.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Feb 13, 2001 | 08:55 PM
Boham92RS's Avatar
Ok, sounds like Por15 is the way to go.. Only problem is that they are welded in. Should I bother to go through the trouble of taking them out to coat them or coat them from what I can get under the car?
Old Feb 13, 2001 | 11:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Paint them on the car. The welds need to be painted too, and you shouldn't be able to get them out without making a big mess anyway.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
tmork454
Sep 29, 2015 06:33 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
