LCA RLB Install
LCA RLB Install
When I jack the car up, do I put the jackstands on the rearend or on the frame?
I'm just wondering if there is any tension I should be concerned about when taking the LCA bolt out. I will have the front of the car on ramps. Thanks.
Brad...
Brad...
Put the stands under the frame and when you loosen the bolts to the LCA's, jack the rear up a little so they come out naturally not forced. When you go to put them back in, you may need to bang around a bit. But not to much.
I second what ROCHEAD posted. One more thing to make your life much easier, only do one side at a time. Don't remove both LCAs, remove and replace one side at a time.
Steve
Spohn Performance: F-Body Chassis/Suspension Specialists
Steve
Right on. Thanks guys. Gonna start that project today. Does anyone happen to have any templates for the RLB's??? Would make fabbing them a lot easier and faster.
Thanks...
Brad
Thanks...
Brad
1992rs/ss
Jan 31, 2025 05:10 PM
ambainb
Apr 25, 2016 09:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
NBrehm
Aug 5, 2015 07:57 PM
