Factory installed Check engine light for finished brake pads
Old Apr 15, 2001 | 06:36 PM
vortech305's Avatar
I read in my car manual that 92' camaros came equiped with sensors in the brake that light up that brake light in the odometer once the pads are done. So far never seen that light come on. The only obvious way i found out i needed brakes, squeeling, and putting my foot through the floorpan to stop the car. Could the sensor be broken, is it true if such a factory option was available for 92' camaros. I dont think mines is broken cause when i start up the car the brake light goes on then off.
Old Apr 15, 2001 | 07:41 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Never heard of a wear sensor on the '92 Camaros (not even on the 4th gens). What manual are you reading? I really don't think its correct.
As for the light coming on, havn't you noticed that all the lights come on when you crank it up? Its called "bulb check".
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Apr 15, 2001 | 11:43 PM
vortech305's Avatar
not only is it a bulb check its a sensor indicator. Im reading the manual from the factory and it says once brakes pads need repairing brake light will go on.
Old Apr 16, 2001 | 02:17 AM
Josh 91RS's Avatar
Pretty sure the only function that light serves is to let you know your parking brake is on. Besides, thats like saying that you should wait for your oil light to come on to change your oil...even if thats how it worked, i dont think you should wait for the light to come on.
Old Apr 16, 2001 | 05:59 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
It appears you are misunderstanding the information. The light WILL come on if there is a loss of fluid, which would mean that the BRAKE SYSTEM needs repaired, but it will not come on if its just the pads wore out.
If you look at the combination valve (aluminum block w/ brake lines coming out of it under the master cylinder) you will notice a wire coming out of it. This is the "Pressure differential switch" portion of the combination valve. A loss of fluid wil cause an imbalance of pressure in the valve, and will trigger the light to come on.
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Old Apr 17, 2001 | 08:51 AM
vortech305's Avatar
thanks guys, just one more quick question. On top of the RPM odometer there are those sensor lights such as service engine soon,etc. I see an oil level sign but it never lights up. Even when i start up the car. Could it be a bad bulb or that my car dosent come equipped with that type of sensor. Never had an oil pressure or level problem. so what could be the problem.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Apr 17, 2001 | 07:15 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
It was an "option" for the V6 cars. Its easier for GM to put the lens in all the cars, and then just wire only the "optioned" cars.
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Old Apr 18, 2001 | 12:07 PM
vortech305's Avatar
So in other words the oil level lense in the odometer is not functional??
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
