How do check to see if it is the axle or the rim making the car wobble at slow speed.
Old Apr 28, 2001 | 12:21 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
the car will wobble a little bit at about 10 mph, and then after that you don't notice it after that, How do I check it? Could it be the tire?Thanks the rear is a 9 bolt.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Apr 28, 2001 | 07:15 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Put it up on a pair of jackstands and put in gear and watch the wheels as they spin...
KAM
Old Apr 28, 2001 | 11:02 PM
87 Trans Am TPI's Avatar
Could it be your tie-rods?
Old Apr 28, 2001 | 11:09 PM
NTChrist's Avatar
I had something similar happen to my car. The car would wobble at low speeds, but wobbled so quick @ high speeds, that it was unnoticable. I freaked out 'cuz I though something major was out of kilter.
I realized that I had broke a belt on a tire (excessive burnouts may be hazardous to your tire's health ), and that one rear tire was causing the whole car to shimmy.
No guts, no glory.
Old Apr 29, 2001 | 01:38 AM
BLACK Z's Avatar
Car: 86 Z28
But if the rear tire is wobbleing, how do i know if it is the rim or the axle? How can I check just the axle? I am almost 100% sure it is coming from the back.
Old Apr 29, 2001 | 08:31 PM
83Z28406's Avatar
Car: 83 Z28
Engine: 400
Transmission: Th 350
Axle/Gears: 3.27 9 bolt
you probably have a broken steel belt in one of your tires just run your hands over the tread of each tire you will feel a hump on the tire with the busted belt if thats the problem just remember it could be on bottem so if you dont find it move the car a couple feet to expose the bottems
Old Apr 29, 2001 | 09:35 PM
Fimbulvetr's Avatar
The places where they mount tires have those machines for weight. Most of the better model machines also check rim tolerances at high speed. I doubt it would cost over $20 to have them spin a tire. Im not sure on the drive shaft, but like you mentioned youd like to eliminate the variables.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
MY87LT
Aug 17, 2015 08:43 AM
Exxon Limited
Aug 9, 2015 08:13 PM
Fronzizzle
Aug 9, 2015 01:15 PM
