Brake problems, someone please help.
Old May 4, 2001 | 04:20 PM
Dan87IROC-Z's Avatar
My brakes act like they are only working at like 10% strength. Especilly at low speeds, like going through a parking lot or whatever I have to push the pedal all the way to the floor and push on it hard to get the car to stop, its pretty scary. What could this be, I checked all of my pads and they are all in great shape so it can't be them. I was thinking since its worse at low speeds, could it have something to do with intake vaccum to the master cylinder? Any suggestions are welcome!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old May 7, 2001 | 01:59 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Almost sounds like the power booster. Do you hear a "hissing" noise from it with the engine running?
FYI, the power booster is the large round thing b/t the master cylinder and the firewall.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
