Need help End links
Old Jul 24, 2010 | 12:40 PM
harp_scott's Avatar
Car: 91 RS
Engine: 350 Carb
Transmission: TH-350
Axle/Gears: Stock 3.23
Need help End links
Just swapping out end links today. 91 RS. No matter how I jack the car or put a load on it, It seems the end links are too short. I ran the part numbers, they are correct. Any help would be appreciated.
Old Jul 24, 2010 | 12:51 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Need help End links
front or rear?
front, with the suspension loaded on both sides, they should work just fine, rear, depending on what length was there before, you may have to loosen the mounts on the axle, then put the links on, then retighten the axle mounts, with the suspension load of course.
Old Jul 24, 2010 | 01:01 PM
harp_scott's Avatar
Car: 91 RS
Engine: 350 Carb
Car is on the ground right now. I cannot get the washer ,bushing, and nut on?
harp_scott's Avatar
Car: 91 RS
Engine: 350 Carb
Front
Old Jul 24, 2010 | 01:52 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I've run into that before. You need to loosen the 4 sway bar-to-frame mounting bolts(2 per side) slightly so that you can pivot the bar down enough to get the nuts started. Once you have both sides started you tighten up those 4 bolts then torque the end links to spec.
1992rs/ss
Jan 31, 2025 05:10 PM
GTAman
Mar 15, 2019 11:40 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
