Which company makes the popular front end rebuild kit???
Old May 27, 2001 | 10:36 AM
Chaotic Firehawk's Avatar
I hear it before,but forgot.Which company makes a good,but reasonably priced front end rebuild kit for our cars?
Chaotic Firehawk can be found wondering NEThirdgen.org and 3rdgen.org
"A musclecar, by definition, is a powerful and sporty vehicle that must be able to spin its tires at will. The Firebird Trans Am is capable of laying down twin black streaks of rubber several hundred feet long. We wanted to be sure it could, so we did it a half dozen times in the name of automotive science."-MotorTrend
Old May 27, 2001 | 10:25 PM
buddman91rs's Avatar
PST performance.......$149 it's a poly-grahphite front suspension rebuild kit. they also sell a KYB strut/shock package for $129 also sell graphite bushings galore, and sway bars
1991 RS LO3
mods: 14" chrome air cleaner, straight-piped after cat exhaust with one chrome dual tip on the left side.
future mods: headers, removing smog equipment, and as many cheap mods as i can find
aol s/n: budman8503
RACECAR spelled backwards is RACECAR
Old May 27, 2001 | 11:54 PM
Thanks,do they have a website?
Old May 28, 2001 | 01:36 AM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
I'll second that for PST, since I got mine from there. Great quality!
www.p-s-t.com
Hope this helps!
Old May 28, 2001 | 09:57 AM
Old May 28, 2001 | 10:03 AM
91RedBigFinZ's Avatar
Is this stuff easy to install at home, or should a shop do it? Doug
Central Indiana Camaro Club member since Oct. 2000
1991 Z28 - 51,000 miles.
Dyno Results: 226.4 Max Hp; 310.4 Max Torque (ft-lbs)
All power options leather. 350 TPI:
K&N; Airfoil; Custom 'Ram-Air'; Slp Runners;Poweraid TB spacer;
Fastchip;
SLP Headers; Borla Catback 50% open; Dual factory Cats;
March underdrive pulleys;
Accel Extreme 9000 wires, Accel coil; Hypertech rotor & cap; NGK platinum plugs;
Manual fan switch;
TB coolant bypass; smog pump delete
Spohn subframe connectors (black powder coat);
Pirelli P7000 Z245/50/R16 all season tires;
Energy suspention motor mounts
S Cobra Radar Detector; Z28 SS Floormats;
Technalon IV car cover (now on my dad'a 2000 Berger SS).
Old May 28, 2001 | 04:55 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Read the manual, get a coil spring compressor, and do most of it yourself. I think they (PST) have videos to help you out. Take the ball joints to a machine shop to press them out/in, and get it aligned as close as you can. Take it to the alignment shop and you're done. Better have a lot of penetrant and a BIG cheater bar!! Good luck..
Old May 28, 2001 | 07:50 PM
I'd let a pro handle this thing.Better have it done right,then screwing up your car doing to yourself
Old May 29, 2001 | 03:52 AM
Sinister's Avatar
Since this is the place maybe someone has had this problem that I am having. I just put in a new front end kit from PST and it's been in there since Jan. Now all the sudden the front end is really squeaky. It's coming from the bushings on the control arms. Why is that and is it going to go away after awhile? Or am I SOL and have to replace them again? Any ideas?
Old May 29, 2001 | 11:01 AM
Norm Peterson's Avatar
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
<font face="Verdana, Arial" size="2">Originally posted by Sinister:
Since this is the place maybe someone has had this problem that I am having. I just put in a new front end kit from PST and it's been in there since Jan. Now all the sudden the front end is really squeaky. It's coming from the bushings on the control arms. Why is that and is it going to go away after awhile? Or am I SOL and have to replace them again? Any ideas? </font>
Squeaking is more common with polyurethane kits than polygraphite. Greasable bushing designs (or greasing mods that you can make to plain bushing designs) allow you to keep things quiet. For shorter durations a shot of WD-40 or perhaps spray assembly lube will work. Mostly it's the nature of the poly material and it's a nuisance more than anything.
Norm
1979 Malibu w/some cornering tweaks and a few other interesting things
Old May 29, 2001 | 05:29 PM
Sinister's Avatar
Yes it is a newsance...I would rather listen to a newborne baby cry all day than listen the squeak on the frontend. Thanks for the help.
Old May 30, 2001 | 04:02 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
So basically, no matter which kit you install, you'll get squeaks? Geez, what a shame...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 30, 2001 | 08:00 PM
The squeaking tells you that you have a performance rebuild
Old May 30, 2001 | 08:41 PM
Sinister's Avatar
I didn't think about it before but won't the WD-40 eat at the polyurethane bushings? Is it safe or is there another way to go about it? Also what's the difference between the Polyurethane and the Polygraphite bushings? Commons sense from the way it sounds would be that one is going to squeak and one isn't. But I could be way off. ????
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
italiano67
Dec 11, 2016 09:21 AM
bellez77
Sep 5, 2015 08:39 PM
