Quick Ratio Steering box?
Old May 31, 2001 | 04:07 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Will it tighten up the steering considerably? Where can I get one? How much will it cost? Are there any aftermarket manufactures, or do I have to buy GM? Thanks guys!
Old May 31, 2001 | 04:29 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i'd look for one out of a 91-92 Z28 or T/A from a salvage yard
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old May 31, 2001 | 04:41 PM
Scott_92RS's Avatar
Car: 1992 RS
I really dont want a used one. Is there any way to check to see if it is still good before taking it home? If so, then I might consider it, otherwise, I might want to go with one from www.agrsteering.com .
Old May 31, 2001 | 08:18 PM
Lostsol's Avatar
Howdy there, if I were you I'd give the guys at Global West a call before you get an AGR box. The reasoning is Global West races everything they build, and I believe they know what they're doing. Besides, they engineered their blueprinted steering gear to use the stock power steering pump. With AGR I'm fairly sure you have to buy an upgraded version of that as well. Basically, I have a Global West box and am happy with it. I'm not 100% sure but I think their website is www.globalwest.net Just my two cents folks, take care now.
Old Jun 1, 2001 | 03:39 PM
Scott_92RS's Avatar
Car: 1992 RS
I emailed Global West. Apparently they do not sell power steering boxes anymore. Anyone know where else to get a GOOD one? Thanks
Old Jun 1, 2001 | 05:48 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Hey Scott...
I have the 1161p Box from AGR and have been very happy with it. The only thing i didnt like was the steering effort was a little easyer than my stock 90 IROC box was. So I had them install a 220 torsion valve in place of the 210(free of charge)that the box comes stock with. This is pretty close to the stock valving found on the IROCs. When you order they will install any valve you want. You do not need a new power steering pump with the AGR box. The stock one has worked fine in my car for over 60,000 miles. I paid around 310.00 for mine thru summitt.
If the box you have now has a lot of slop then it will make a big difference. If the rest of the suspension is worn you will need to replace that to get the tight steering you are after. If you have any questions send me and email and i will help as much as I can.
Take care,
Mike
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Jan 23, 2002 | 11:05 AM
robert C's Avatar
id search the {parts} yard. there are two irocs in a yard by me im going to get one for my 90 rs for $26 with 30 day war.
{ let me see $30 dollars or $300 dollars} u choose.
email me maybe i can get u one
see ya rob
Old Jan 23, 2002 | 11:51 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
If you're searching the yards for a used one, the best box is stamped "XH" on the cover.This came with 91-92 Z28,TA and others with F41 Suspension Option and 16" Wheels.
-Rich-
Old Jan 23, 2002 | 06:07 PM
robert C's Avatar
so i can just look for the rpo.code { f41 } in the glovebox
Old Jan 24, 2002 | 12:40 PM
CODY BEHNKE's Avatar
Actually the best were marked "Z"
Amillionoh7
May 24, 2020 08:01 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
zayne0
Aug 24, 2015 07:22 PM
happyhapka
Aug 15, 2015 04:42 PM
