rear rotors
Old Jun 24, 2001 | 04:01 PM
a383z's Avatar
rear rotors
I have to replace the rotors on the back my 92, I've got a fourth gen rear. Does any one know where I can get a set of cross drilled for less than 105, that is the cheapest I have seen on the web. Oh and by the way it makes no sense to got to regular rotors an auto parts store especially since cross drilled rotors are about the same price(like twenty more)but if anyone can help me that would be great.
1992 383 Z-28 w/SuperRam intake and ACCEL DFI, PA Racing K frame,SS hood,SS rims
Old Jun 24, 2001 | 04:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Why do you want cross-drilled rotors?
Old Jun 24, 2001 | 10:03 PM
a383z's Avatar
Cross drilled rotors stop better I know that because I use them on my monte carlo, I am going with cross drilled up front soon and I want the look to match. Plus the the price difference so far between regular rotors is like twenty dollers so I figured I might as well go with cross drilled rotors.
Old Jun 25, 2001 | 02:18 AM
Omar's Avatar
With the advancement of today's brake pads, cross drilled rotors are merely for cosmetics.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Jun 25, 2001 | 10:02 AM
a383z's Avatar
Well its mostly a show car so mostly it is for looks. but the basic principle No matter how good the brake pads cross drilled rotors should help you.
Old Jun 25, 2001 | 10:48 AM
AntiVTEC's Avatar
Cross drilled rotors help by allowing the heat to dissipate alot faster, creating a fade free braking feel.
Old Jun 25, 2001 | 09:37 PM
Metalifann's Avatar
I thought that cross-drilled rotors were supposed to help the gasses that form under hard braking between the pads and rotor escape. However, these gasses are created only under extremely heavy braking and only with older organic brake pads. Thirdgens never had organic pads on them, only semi-metallic which aren't supposed to create those gasses.
Old Jun 25, 2001 | 10:47 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Cross drilling was to let the pad gasses escape and prevent fading during racing conditions, but as mentioned modern pads don't have this problem. Some say that cross drilling actually hurts performance by reducing swept volume.
Old Jun 26, 2001 | 08:39 AM
a383z's Avatar
I thought brake fad comes from the brake set up getting hot under hard braking. And crossdrilling helped to cool the brake assembly.
Old Jun 26, 2001 | 05:15 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I don't think crossdrilling has any real effect with today's brake pads. They're probably mostly for looks and if you've got a car you want to look cool then go for it. I love the way they look. But I have heard that crossdrilling actually decreases the overall strength and rigidity of the rotor.
Old Jun 27, 2001 | 01:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
<font face="Verdana, Arial" size="2">Originally posted by a383z:
I thought brake fad comes from the brake set up getting hot under hard braking. And crossdrilling helped to cool the brake assembly. </font>
Yes, old pads used to start to "evaporate" when they got hot, this created a cushion of gas between the pad and the rotor. Cross-drilling gave this gas somewhere to go.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
