Ebay Front End Kit??? anyone?
Old Sep 4, 2010 | 01:33 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
http://cgi.ebay.com/ebaymotors/SUSPE...ht_3187wt_1165
look good to you guys??? cuz i need these parts but just not sure if theyre good
Old Sep 4, 2010 | 01:54 PM
mikeirocz1's Avatar
Car: 91 RS and 88 IROC-Z
Engine: 305 TBI and 383 Carb
Transmission: 700R4/2200 stall & 700R4/3500 stall
Axle/Gears: 3.42 posi and 4.11 posi
Re: Ebay Front End Kit??? anyone?
I bought one of those kits and it didn't last very long. I'm replacing it now with moog part's.
Old Sep 4, 2010 | 02:06 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
mmm...alright...does moog have a kit? how much? links?
Old Sep 4, 2010 | 04:29 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
You can buy Moog parts at pretty much any auto parts store (I.E. Napa, Checker/O'Reily, Autozone..) Don't think they do a "package" though.
Spohn makes parts too, I've heard good things: http://www.spohn.net/shop/1982-1992-...sion-Steering/
Old Sep 4, 2010 | 04:39 PM
dust3r's Avatar
Car: 1986 z28 & 1992 z28
Transmission: 700-R4
I have a mix of Moog and Spohn parts... I like the Spohn parts because they are zinc coated and the tie rods were easier to get threaded into the tie rod adjusters than the Moogs were. Also, with the Spohn tie rods and adjusters I am able turn the adjusters by hand very easily.
Old Sep 4, 2010 | 06:04 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
hmm...alright..anyone got a list of parts needed for the front end?
Old Sep 4, 2010 | 06:07 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
found the sticky O.o
Old Sep 5, 2010 | 12:55 AM
You probably won't need to replace the pitman arm though, if that was listed as a part needing to be replaced in the sticky
Old Sep 5, 2010 | 01:26 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
and whys that?
Old Sep 5, 2010 | 03:44 PM
If you've looked at it, it's really very very solid, and it's not a "wear" part like many of the other front end parts (Like ball joints and such) are.
Old Sep 5, 2010 | 03:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
what he said. the pitman arm is a not wear item, there are no joints or anything on it. Only time to replace it would be if the arm is damaged from an accident or somebody cutting it for whatever reason.
Old Sep 5, 2010 | 04:10 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
ohh i see...what side is it on?? driver?
Old Sep 5, 2010 | 04:31 PM
The pitman arm is on the driver's side, it's the arm thing that transfers movement from the steering box to the center link
Old Sep 6, 2010 | 06:41 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
well...hehe..i got in a little 1 car accident a while ago. thru my alignment off. MIGHT have damaged the pitman arm...
Old Sep 6, 2010 | 06:48 PM
Ouch, that sucks. I doubt the pitman arm itself was bent up though, the "weak links" in the steering system are gonna get mangled up before it does. Post a pic of it if you can, but I'd bet the pitman arm is alright
Old Sep 6, 2010 | 06:56 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
yea it does ill get some pics of the under side later..pretty hot out right now
Old Sep 6, 2010 | 06:59 PM
Maeryk's Avatar
Car: 89 Formula 350
Engine: 355 long block TPI
Transmission: auto
Axle/Gears: Richmond 4:10 Eaton Posi
Do you know you need steering parts? Or did something just get banged out of alignment that you can realign?
Unless you have actual bad parts, there might not be a need to replace the whole system. You might just need one adjuster or something, if it stripped it out when it shifted the alignment.
Old Sep 6, 2010 | 07:46 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
the centerlink is kinda rusted in the....center -_- lol...
and the dude at pep boys said my idler arm was bad? so he couldent re-align it all the way...so why not replace all the 21 year old parts?
Old Sep 6, 2010 | 07:49 PM
Maeryk's Avatar
Car: 89 Formula 350
Transmission: auto
Yeah, i had to replace the idler arm and center link on my previous bird. It wasn't too tough, did it myself, and got the alignment really close with thread counting and careful measuring of the tires.
If you want to throw a full kit into it, no reason not to. Those ball joints though? Rent the tool. You may think you can do it with a vice and a big hammer.. but rent the tool.
Old Sep 6, 2010 | 08:12 PM
one92rs's Avatar
Car: SOLD!!!!!
i dont remember who i bought it from but i ordered one of those kits. it was 149.99. when i got it in it was moog parts.
Old Sep 8, 2010 | 04:46 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
ill probably end up doing it myself this way...
links????
Old Sep 12, 2010 | 12:48 PM
stielow775's Avatar
Actually looks like they are moog parts.
This is a 12 part SUSPENSION set of:
2 Inner Tie Rod End 2-ES2227RL 2 Outer Tie Rod End 2-ES2226RL 2 Sleeves 2-ES2032S
2 Lower Ball Joints 2-K6145T 2 Upper Ball Joint 2-K5208
1 Idler Arm 1-K6249 1 Drag Link 1-DS1049
Old Sep 13, 2010 | 01:31 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
the ebay one?
Old Sep 13, 2010 | 02:11 PM
stielow775's Avatar
No I was mistaken ebay one is cheap china stuff.
I am just going to order from spohn or oreilly or amazon for the cheapest moog stuff.
Anything other than moog just isnt durable.
Matt
Old Sep 13, 2010 | 06:52 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
amazon?? gonna check that out...spohn is to pricey for mehh
Old Sep 13, 2010 | 07:30 PM
stielow775's Avatar
I tightened my steering box up and that made a world of diffrence car has 144k miles on it but it was driven easy. I still plan on changing my idler, and my center link, but the rest can wait for 20-50k more miles.
Matt
Old Sep 20, 2010 | 08:56 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
how to tighten the steering box??
Old Sep 20, 2010 | 09:46 PM
stielow775's Avatar
There is a big nut right below the rag joint loosen that then take a spanner wrench or small screwdriver and tighten to 20 ft lbs or approximate then back out 1/2 inch then tighten down locknut. Its a huge nut on the box and you will see little divets. Let me put it this way before i tightened mine up it was sloppier than a cheap yeah. Now its firm and crisp.
Now go down to the one that has the allen head and bolt. Loosen the bolt 4-5 turns turn the allen head all the way in. Make sure the wheels are straight now tighten it till it stops then back out 1/4 to 1/2 a turn. And recheck.
Bingo alot better.
Above worked for me. Yeah your supposed to take out the box.
Old Sep 20, 2010 | 09:47 PM
stielow775's Avatar
http://www.elcaminocentral.com/showthread.php?t=27532
above is where i got the info.
Matt
Old Sep 22, 2010 | 05:28 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
gonna check it out today after class thanks.
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
bellez77
Sep 5, 2015 08:39 PM
